Question about Fender Audio Players & Recorders
My normal channel input jacks have different levels....one is louder than the other...
  • 88 Answers
This is normal
Posted on Apr 26, 2014
Channel 4 is 10 times louder than other channels why? all gains ect set the same nearly blew my speakers
Try swapping the input with another channel and see if the problem moves. Be sure to set the levels down or you may get your speakers this time. If the problem moves the source is the bad guy. If not check the gain setting, not the slider. The gain is normally the top know on the channel.
Jun 02, 2014 | Behringer DX2000USB Pro 7-Channel DJ Mixer...
How to hook up a turntable to the Pioneer VSX-1018AH-K 7.1-Channel A/V Receiver
Different cartridges put out various levels based upon their technology - make sure you are using the proper input for their output. A line level input 1V P-P won't work on most phono cartridges and will require a preamp to boost it to the higher level.
On a surround sound receiver, you should look for an unused input with RCA jacks and just use the Red and White leaving the Yellow/Video unused.
Dec 02, 2013 | Technics Audio Players & Recorders
I have to turn the master switch all the way on to hear the music and then my microphones are too loud
Watch videos on YouTube about proper setup of a mixer/amplifier. Proper level setting at the different stages of the mixer is important to balance. You don't give us a clue as to what music you are talking about... if it is from a device plugged into the tape inputs for instance, the fault is your source is NOT providing adequate line-level to those jacks and you are trying to compensate with the master level. The master level should probably be around60% up in normal operation.
Oct 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
On a sony str-dh710, is there any difference in the amp. level between setting the distance levels and the db levels? Also using the Video 2 input on the front of the reciever I'm not able to get any...
.. or read the manual about setup and getting multichannel audio from 2-channel sources. Calibration and Selecting a Sound Field.
Distance is linear spatial separation of two points. dB is audibility, sound pressure level, volume. The distance setting affects how the various channels are delayed to arrive at the primary listening position at the appropriate time to provide a plausible sound field. Simply making one or more speakers louder or softer will not affect the spatiality of it.
Apr 18, 2011 | Sony STRDH710
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
I just bought a pioneer pl-200 turntable at a flea market. I plugged it into an old am/fm/8-track amp's phono input and I know the amp cranks on fm but on phono, it's very low sound. It does get louder...
Turntable signal outputs are very, very low amplitude and either have to pass through a pre-amp before being connected to an amplifiers "ordinary" inputs (e.g. aux), or connect to an amplifier's specific turntable input in order to give the "normal" levels of volume.
This is because the cartridge (the bit that has the stylus or needle on it) can only generate very small amplitude signals.
As turntables are now outdated, a lot of amps no longer have a turntable input any more.
Unless you can also find a cheap pre-amp or an old amp with a turntable input, you may have wasted your money.
Sep 21, 2009 | Audio Players & Recorders
Receiver works with digital signal input jack only.
Are you talking about the 6 channel input with all RCA jacks? Please explain a little better, it is very hard to know how you have it connected without a very good description since I can not put my eyes on it. You may need to check the settings, it may have the rears muted. More information from you will help me to be able to help you.
Dec 27, 2008 | Kenwood VR-405 Receiver
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Glenn Mayer
Glenn Mayer
 Grubhead
Grubhead
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
