Question about Ovens
Kenmore self cleaning oven...model # 790.95661100...when we plug it in the broiler element comes on and won't go off even with everything turned off....can you help...thanks,Joe
    Brigadier General:
  • 3,917 Answers
Hi
Sounds like your broil element is grounded. Pull your range out from the wall, then keep it unplugged, then take off your back access panel then You would need to ohm the broil element with an ohm meter, remove the wires that connect to the element terminals, then place one meter probe on one of the element terminals, then the other meter probe on the metal chassis of your range, there should be no continuity. http://www.applianceaid.com/electrical_testing_tips.html
Mostly this is caused by a stuck broil relay on the Electronic Range Control (ERC) board. In most cases you will need to replace the ERC.
1. Unplug the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, note them down.
5. with the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board..
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting fixya.com
Posted on May 13, 2010
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: oven and broiler will not heat top works fine kenmore 790
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Oven takes forever to preheat. Only the bottom oven element comes on during preheat.
Try checking the heating elements on the top might have come loose
Apr 22, 2016 | Ovens
Why don't top oven broiler and bake elements heat?
we had that problem once. it turned out to be the control switch was broken
Apr 10, 2016 | Kenmore 27 in. Electric Self-Clean Double...
Broiler wont light everything else works..model ffgf3023lwa
Hi Chris Stewart - If the bake element and the top of the range works, but just not the heating element, then you possibly have a bad broiler element or connection. However, if you are experiencing other performance difficulties, then the control board may possibly be faulty and needs replacing. Consult a professional for an accurate diagnosis.
Feb 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Here is the problem. the clock and everything works but when you turn on the oven...nothing, oven or broiler. The elements are good
check your breaker first
flip off and on a couple of times
try the oven again
if still nothing sounds like possibly you did a self clean recently?did you?
what is the model number?
Feb 12, 2010 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Broiler won't turn off even after unplugging and plugging back in.
Check to make sure your broil element is not grounding out causing the element to always stay on when power is applied.
You would need to turn off your house breaker to your oven and check for continuity with an ohm meter between each of your 2 broil element terminals and ground.
Apr 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
