Making a noise I've never heard before
My 5 year old Friedrich SS12J10AR-B seems to be working normally, however it's making a noise I've never heard before. It's a subtle 'clanking' sound, similar to the sound a diesel engine in a car makes.
Does this give any clue whatsoever to what, if anything, might be wrong?
Thanks,
A_C
    Guru:
  • 415 Answers
It sounds like the fan blade is hitting something. Turn the unit off and make a visual inspection inside the unit. With the unit unplugged, turn the fan blade manually with your hand to determine the source of the obstruction and correct. Something may have rusted and come loose inside......or some wires may have come loose. It will require a visual inspection.
I hope you find this to be very helpful to you moving forward.
Please leave a rating. :-)
Let us know if you have any further questions, comments or concerns. :-)
Posted on May 13, 2010
Testimonial: "While I haven't had a chance to quantify the answer, I find it illuminating nevertheless; Thanks!"
Clanking noise coming from Allison Transmission on a 2001 Chrevrolet Silverado 8.1 Liter engine
this does sound like theres a loose line tapping the engine/frame,during warm up the engine idles faster which could make it vibrate faster causing the the clanking or tapping noise,if this has started after trans fluid change,then check the lines running from the trani to radiator sometimes the service person might bang into something causing plastic clips that hold the lines to break,try getting under it and have someone start the truck and listen to see where it's coming from also hold the lines & see if the noise stops,the service guy could have unbolted something & never put the bolt back causing the clank ex.line may have a clip holding it thats bolted to the trani pan ?good luck
Dec 29, 2012 | 2001 Chevrolet Silverado 2500HD
Clanking noise & won't sew
Are you sure you put the correct type of needle in? Normally, if you have any problem, cleaning and oiling will fix it. It sounds like you either didn't tighten the needle screw or you put the wrong type of needle in.
Jun 24, 2012 | Janome Sewing Machines
Lincoln Navigator 2004(?) starting problems
well the wav file don't work, always use youtube.
as to your car, from the description, it's either battery or starter motor related.
Apr 25, 2017 | 2004 Lincoln Navigator
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
I have an 8 year old Friedrich model SS10J10AR unit. The unit keeps shutting off when in cooling mode. When I leave it in FAN only it runs. I tried to reset the circuit board by hitting "Money...
Honestly, repairing and 8 year old AC unit (assuming parts are still available) can cost almost as much as buying a new one. If this is the first time you've had a real problem with it ... You've gotten your monies worth over the past 8 years. But, the decision is yours to make.
Thanks for choosing FixYa.
Aug 10, 2011 | Friedrich QuietMaster Electric SS10J10AR...
Water is draining into my bedroom when a/c is on ihave a freidrich model#ss12j10ar-1? can it be fixed or should i just buy a new a/c?
Before you buy another one, check two things:
1. make sure the unit is tilted back in the window and not forward. The unit has to be tilted back away from the window about a half bubble on a level in order to drain out the back.
2. if the unit is tilted in the window properly and still draining out the front, you will have to take the case off the unit and wash it out good with a hose and sprayer. If the unit is not rusted out on the bottom, the drain is stopped up that drains the water from the front coil into the base of the unit. The water should be draining from the front to the back, and excess drains outside on the ground. Hopefully, it just needs a good cleaning. Hope this can save you from buying a new unit. Stay cool. Mark
Jul 10, 2011 | Friedrich QuietMaster Electronic SS12J10AR...
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Clanking noise heard when braking at low speed and taking off
Clanking? Im Guessing Brakes But Please Clarify The Sound. Is It Off And On Or Continuous When Its Doing It?
Jan 14, 2009 | 2002 Lexus RX 300
Maytag dryer making clanking noise
I had this problem and the cause was a loose screw holding on one of the "paddles" inside the drum. I removed the door, front panel, lifted the top, manually rotated the drum until I saw the screw head which had worked loose and was slapping the side of the dryer. A quick tighten of the screw and the noise was gone.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
