Hi my cousin is having issues with her pc when started up shes getting a no video input message? what could this be?
    President:
  • 548 Answers
Well, try to remove the graphics card and plug back in.( it may be a loose contact)
Test the graphics card on another computer and see if it does the same thing. If so, then you have to buy a new VGA card. If not then there could be a problem with the motherboard.
If you need further assistance, just leave a comment. Cheers
Posted on May 13, 2010
A friend of mine have a sony vaio vgc-rb38g desk top and she has a video card in her unit which was being used since purchase and it started giving her the message no input signal and the unit goes to...
Please check your video card for dirty conection ports and has it cleaned . Retry your PC. If problem persist, your video card is defective and need for replacement.
Regards
Sep 28, 2011 | Sony VAIO VGC-RB38G PC Desktop
Hello, I accidentally changed the resolution too high. And all I get is a message on the screen that say's "Input Not Supported" Is there a blind way to fix this? Thanks
Hi
Restart your PC and press F8 and you see the list select the enable VGA option, your PC is started, then set your resolution, and start again in normal mode your problem is FIX.
May 31, 2011 | Lorex (QLR0444) Video Capture
I get an unlock display when I change to vid2 input. How can I unlock the input? Thanks
I had this exact issue.
I was using the digital 2 input for sound. (Toslink cable from my cpu).
It seems I inadvertantly muted the sound on the pc, and this caused the "unlock" message with the L-R speakers flashing on the display.
I restarted my pc; and then unmuted the sound.
3 seconds later; the L-R stopped flashing and I now have sound on Vid2.
Jan 04, 2011 | Harman Kardon AVR 635 Receiver
My LG Plasma TV Model 50PC1DRA displays the following message after powering it up and connecting to cable: "Invalid Format" All of our other in house TVs attached to the same cable are fully...
Hi
Thanks for using FixYa. Invalid format indicates issues with the PC Mode, if the signal is not out of range then check the input source.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Televison & Video
My dell optiplex 360 cannot start and is displaying the message i/o card parity interrupt at f000:268f
mostlikely an input/output card issue, or a motherboard failure. first thing to do, disconnect any i/o card you may have like video card and other expansion cards. Then connect the cards one by one and test the system if the error has stop. If your system has an intg video controller, try using it first to rule out an expansion video card issue. if you've ruled out any expansion devices and you have reseat the CMOS settings of the system, most likely, you need to get a new motherboard or request warranty replacement if still applicable.
Aug 30, 2010 | Dell OptiPlex 360 Desktop Computer
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
Compac presario S5000NX dont start anymore... the pcu is running but see no images
You need to check if the light on the monitor is green on amber.
If its green then you need to turn off the computer, take out the ram, cmos battery, HDD/CD/DVD cables, power cables, and then put them back, this will ensure there is no static.
If still dont work then you need to take the ram out and start the computer, if it beeps then its a video chipset issue. If it will not beep then its you motherboard that has gone bad.
If the light is amber then remove the monitor cable from the computer and see if you get a message on the monitor stating no input signal, if dont then monitor has gone bad, if you get the message, then follow the steps mentioned above.
Regards,
Shrey
Jan 10, 2010 | Computers & Internet
NO SIGNAL INPUT - message
Hi Rick,
Most common cause of this error is when the video signal cables are knocked off rendering the connection from the monitor to the CPU loose. Turn off the PC and secure all connections. Have you had your computer moved or repaired where you need to remove connections? Some PCs have more than one video cards (video output) and you may have connected it in the wrong video port. You can isolate the problem further by connecting your CPU to a known working monitor (office, freind's, neighbor, 2nd home PC). The other way is to isolate the problem is to connect your problematic monitor to a known working PC and see if video will be displayed. If video is present, your CPU's video card has gone bad or the contacts are not seated properly in the slot. Best Regards
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
