Question about Google Computers & Internet
24 DIVDING BY 149
24 DIVDING BY 149
  • 115 Answers
Thank you sir
Posted on Sep 10, 2011
Eng no H238265 RED MOTOR WANT TO NO WHAT size E.g . 149, 179 as don't say on side block holden block
the holden red motor covered a range of capacities from 149,161,173,179,186,202
one site says the number of welsh plugs in the side of the block next to the starter is a method 3 plugs = 149
5 plus (3big,2small=179,186,161 etc
149 blocks have no casting identification where as 179 have HP cast in the block
from what I can find the h indicates 149 as 179 numbers start with m
if the engine number is m--it is 179 high comp built prior to hq cars
for interesting reading go google and type in --engine numbers for holden 149 engine -- and there are many pages of information for reading
Jul 19, 2016 | Holden Cars & Trucks
Why my Honeywell air purified HHT-149 have no power
unplug and wait for 5 seconds, plug it back in again and hold the power button for 3 seconds.
Aug 07, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
How do I locate a replacement battery for my Brill Battery powered mower. Brill PowerAccu 24 Volt
Wow! That is one expensive battery ($149; but free shipping). I simply "Googled" it for you. You may want to do the same and see if you find a better price. But here's what I came up with right away:
http://www.peoplepoweredmachines.com/brill/electric-mower-battery.htm
Best of luck to you.
James
Aug 22, 2011 | Brill Garden
WHAT FUSE IN THE FUSE BOX IS FOR THE ABS ON A 2000 FORD F250
I was able to download a copy of your owners manual here (http://www.motorcraftservice.com/pubs/content/~WOYF23/~MUS~LEN/36/00f23og3e.pdf )
Your owners manual has all your general maintenance answers.
Page 149 - 151 display the fuse box located in the car for ABS as Fuse Relay numbers 15 and 24.
Pages 152 and 153 display the fuse box located under the hood for abs as Fuse relay number 14.
May 29, 2011 | Ford F-250 Cars & Trucks
2002 yukon front end wont engage
2002 GMC Yukon
2002 GMC Yukon
2004 TRANSMISSION Transfer Case - NVG 149-NP (One Speed Automatic) - SUV
TRANSFER CASE NO FRONT DRIVE
Transfer Case No Front Drive
Cause
Correction
DEFINITION: The transfer case is not delivering engine torque to the front propeller shaft.
Review the Symptoms - Transfer Case and perform the necessary inspections.
Viscous coupling faulty 1. Inspect the transfer case fluid for being black. If the fluid is
black, it is most likely caused by a viscous coupling failure.
2. Test for a faulty viscous coupling. Refer to Transfer Case
Description and Operation.
3. Disassemble the transfer case. Refer to Transfer Case
Disassemble in Transfer Case - NVG 149-NP3 Unit Repair.
4. Inspect the viscous coupling for a bulged cover. Refer to
Cleaning and Inspection in Transfer Case - NVG 149-NP3 Unit
Repair.
5. Replace the viscous coupling if it is faulty. Refer to Transfer
Case Assemble in Transfer Case - NVG 149-NP3 Unit Repair.
Planetary carrier faulty 1. Disassemble the transfer case. Refer to Transfer Case
2. Inspect for faulty planetary carrier components. Refer to
Repair.
3. Replace any faulty planetary carrier components. Refer to
Transfer Case Assemble in Transfer Case - NVG 149-NP3 Unit
Repair.
Oct 19, 2010 | GMC Yukon Cars & Trucks
Error 0100
E100 BD error has occurred. • The laser unit has a fault. • The BD PCB has a fault. • The BD PCB has a fault. • The laser driver PCB has a fault. but it could also be the CCD unit
Mar 18, 2010 | Canon imageRUNNER 400S Copier
Code 803
E803 (The output voltage of the composite power PCB has a fault.) Cause Wiring Composite power supply PCB (J208) Continuity DC controller PCB Composite power supply PCB
• If it does not turn on, see "The scanning lamp fails to turn on." • If it turns on but is dark, replace it (its ends may be blackened). Correct the connection. Connect it securely. Replace the harness. Replace the DC controller PCB. Replace the composite power supply PCB.
Turn off and then on the main power. Is the problem corrected? Does the scanning lamp turn on when the Copy Start key is pressed? Or, is it dark after it has turned on. Is the connection between J111 on the DC controller PCB and J204 on the composite power PCB good? Is the connection of the connector J208 on the composite power supply PCB normal? Check the 24-VDC line between J111 and J204. Is its continuity good? Is there an output of 24 VDC at the J111-1 and J111-3 on the DC controller PCB
Mar 16, 2010 | Canon imageRUNNER 400S Copier
Need to change the time on calculator
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position.
Date:
Enter in the order of month, day and year, then press date/time button
to complete the entry.
Use ▪ to separate month, day, and year EXAMPLE 3▪13▪2009.
When (date/time) button is pressed, the number entered is evaluated
and displayed as “date”
Time:
Enter in the order of hour, minutes, then press date/time button to
complete the entry.
(There is no entry available for the seconds value. The
clock starts at zero second.)
Use to separate hour and minute values EXAMPLE 8▪15
When is date/time button is pressed, the number entered is evaluated
and displayed as “time
When settings are complete place the switch back to GT
Mar 11, 2009 | Sharp EL-1197PIII Calculator
I have red x flashing have tried to reset think it;s frozen
On your device you may have a corrupt file that is causing the issues that you are experiencing. The solution to this is to completely remove the software from your device and reinstall it again as described in the steps below. Please ensure that you have the latest TomTom Home software installed on your computer:-
You can download and install the latest version of TomTom HOME from the following link:
http://www.tomtom.com/home
Once you have the latest version of TomTom Home installed, please follow these steps:-
STEP 1. Creating a Manual backup of your TomTom
• Charge your unit for at least two hours (preferably via the home charger)
• Perform a reset on your device (see: http://www.tomtom.com/6965 )
If you have not made a backup yet you can do so by making a manual backup of your TomTom. To do this, please look at the following web page:-
http://www.tomtom.com/3171#backup
• Connect your TomTom to the computer
• Open My Computer, you should see the TomTom as a removable drive, double click into it. (on a mac you will see the TomTom as a disk drive on your desktop)
• You will see a list of files and folders.
• Copy all of the folders on the TomTom, one by one to the backup folder.
• This can take up to 1 hour to complete depending on the device.
• If you get any error messages while copying, move on to the next folder and copy that to the backup folder.
• If possible, please make a note of any error message that occur while copying the folders, and make a note of which folder causes the error message.
IMPORTANT: We advise you to follow the next steps ONLY if you have made a successful backup of your device as described in step 1. If you are unable to complete step 1, please reply back with a list of yellow folders that you have managed to successfully copy to your PC and also reply back with any error messages that you receive at this point.
STEP 2. Format the hard-disk,
• Open 'My Computer'
• Right click on the TomTom icon (the device should be seen in drive E,F,G,H,I etc) and select 'Format'.
• Do a full format by selecting FAT 32 and click on Start, do not select 'quick format'. The TomTom is now formatted.
• Disconnect the TomTom from the computer and switch it on. It will load up with a red cross on the screen.
• Reset the TomTom with a paperclip in the reset hole for 30 seconds, see http://www.tomtom.com/6965 in how to do this.
• Once Reset, switch the TomTom off, disconnect it from the computer and then switch it back on again, it will still show a red cross on the screen.
STEP 3. Restore the Folders to the TomTom
• Connect your TomTom back to the computer and make sure it is switched on
• Go to your backup folder on your desktop, double left click into it. You will see all of your backup folders.
• Copy the folders one by one to the TomTom by right clicking on the folder, select copy then open My Computer, double left click onto the TomTom drive and choose paste.
• Turn the device off (with the on/off switch) and disconnect it from the computer.
• Switch the TomTom back on.
STEP 4. Update your device
• Open TomTom Home
• Connect your device to the PC
• A list of updates should appear, if not, click on Update my Go
• Select only the program application update.
• Click on Update and Install.
• Once Installed, open TomTom Home
• Click on 'Device -> Disconnect Device'.
• Switch your TomTom On to complete the installation.
The Application is now installed, and your TomTom should now be working.
STEP 5. Run the Clear Flash Tool
• Close TomTom Home. (on a PC, make sure you close TomTom Home from the system tray in the bottom right hand corner of your screen by the computer clock)
• Download and run the clear flash tool from : http://www.tomtom.com/updates/clear_flash/clear_flash.exe Make sure your TomTom is connected to the computer and switched on when you do this.
* IMPORTANT *
If you have any issues with copying the contents of the TomTom to your PC and back again, please let us know and state what error messages, if any, that there are.
Please reply back with the details of what happens.
Jan 10, 2009 | Tomtom ONE GPS Receiver
TE Code flashing what do this mean?
Error code tE is THERMAL ERROR. It is possible that the thermister has failed, but the most common cause is inlet water being hotter than 149 degrees (F) The optimal inlet temperature is 120 degrees minimum.
Always check that before you suspect hardware failure.
What did you find to be the problem? Thank for a reply.
Dec 23, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Computers & Internet Logo
Top Google Computers & Internet Experts
Robet
Robet
Sunil Pratap Singh
Sunil Pratap Singh
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
