Question about Pride Sundancer 3 Wheel Mid-Size Scooter
I have a code of 3 blinks and the 1 on my scooter. when I was using it it was almost like the throttle cable came loose or broke. How do you go about opening the front up to check this out?
    Scholar:
  • 63 Answers
Hello, .If its feeling really sloppy and you scooter is not moving and all your getting is beeping or blinking lights yes,you are looking at lost or loss set screw .This also could be a broken throttle pot as well too.
Check under your tiller where your throttle is there is a little pin hole ,This pin hole is right in the middle of your your throttle arm, this set screw that hopefully is still in your throttle arm require a allen head/ allen key small .make sure its still there if not you may have to go radio shack ,or hardware store to find one that small .but if it is the and is really lose make sure that throttle arm is lined up ,use that allen key to tighten it up.
That should fix that.
Now if the set screw is still there and its tight but the throttle arm is still sloppy ,you most likely have a broken throttle pot .Now the Part your looking for is throttle pot ,there should be two Philips head screws holding it down.
Good luck when let us know how it go's ,Hope i was of some help.
Posted on Jan 20, 2011
My sonic 3 wheel scooter will not go status light blinks 3 times the 1 time,3 times then 1 time ect, batteries fully charged unit is in gear what is wrong
Pride Mobility Products Corp. - Product Owners Manuals ...
www.pridemobility.com > Resource Center
Pride MobilityProduct Owners Manuals & Specification Sheets ... Jazzy Elite ES PortableSpecifications ... I 02/03. Jet 3 Ultra ... Travel Scooter Throttle Control Lever OperationProduct Insert .... Brochures · Owners Manuals · Basic Operating Instructions · BasicTroubleshooting Instructions · EMI / RFI Information · Warranty Information.
Sep 25, 2015 | Pride Sonic 3 Wheel Portable Scooter
What makes my status light blink 3 times then 1 time,3 times then 1 time ect? unit is in gear batteries fully charged
hi Alto, it really depends on the controller used what it actaully means ? if it a blue colour one , then it's a curtis...
this is what it means
1. Misadjusted throttle.
2. Broken throttle pot or throttle mechanism
The throttle is no longer dead centre...
Regards
Rob
Help me , help you ...
Rascal Candy Apple. Why did it stop moving while I was driving it?
On the rascal, if your driving along and it suddenly stops, the throttle lever could be bad or the speed control could be bad or both. A battery lead maybe loose. The tiller cable may have slid back causing line interruption.
The flashing 4 indicates current timeout, the scooter may have been going up a steep hill, over heating the motor, turn off and allow motor to cool. then try again. if this happens on flat ground then check the parking brake, it maybe hanging up causing the motor to over work. Other trouble-shooting information for rascal, scooters on my free app.
Scooter Doctor App
Aug 11, 2015 | Health & Beauty
My scooter won't start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Fuel line to carburetor or throttle body pinched or kinked.
8. Carburetor float stuck.
9. Fuel injectors clogged.
10. Severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
11. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
12. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and CDI box.
Spark plug cables in bad condition and shorting check for leakage in the dark, cable connections loose, or connected to the wrong cylinders.
13. Ignition timing incorrect due to a faulty MAP, CKP, O2, TPS, sensors.
14. Faulty neutral, clutch lever, or kickstand safety switch.
15. Faulty fuel pump or fuse or relay.
16. Faulty CDI box.
17. A stuck bent or burnt valve.
18. Tip over sensor needs a reset.
19. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Scooter Troubleshooting Scooter won start All about Scooters
Scooter won start
Yamaha YP125R Service Manual
OEM parts for Yamaha
Yamaha Max YP125RA Owner Manual
Feb 12, 2015 | 2011 Yamaha XMax 125
Light blinks six times and stops and then blinks 6 times and stops. Dalton mobility electric scooter.
Could be throttle control not in centre position on switch on. check the throttle control or wig-wag is not loose.
Oct 05, 2014 | Health & Beauty
Why won't my pride legend start?
The legend has a Curtis controller. The flash codes you provided points the problem to a faulty throttle pot. If a new throttle does not fix the issue, then your problem is the controller itself.
Sep 03, 2014 | Pride New Mobility Legend 4 Wheel Scooter
I have a IMC Heartway Gypsy and the power light blinks 5 times and the scooter won't run. I have just replaced the batteries. Is there list of what each code means? Thanks
1. Battery low
2. Battery charge is too low
3. Battery voltage too high or charger still connected
4. Current limit. turn scooter off for a few minutes and then on
5. Brake lever in freewheel mode
6. Throttle lever not in centre on switch on or faulty
7. Speed pot or throttle pot error
8. Motor volts error
9. Other internal fault/control fault
Hope that helps you.
May 18, 2014 | Pride Mobility Products Go Go Ultra X 3...
Sonic pride scooter won't move led light flashes 3 blinks then 1 blink?
the slot in the pot stem has to be dead centre..
Regards
Sep 02, 2012 | Pride Sonic 3 Wheel Portable Scooter
Scooter charges but doesnt run
could be one of many problems is the battery indicator blinking on the control box if so
check on/off switch
check seat switch
free wheel switch located in the slot on the back right side of the battery cover check for proper position
also there are 2 small lights just to the lower left and lower right of the battery indicator that will blink a error code examples are 1blink pause 2 blinks or 2 blinks pause 2 blinks and many others if you have the error codes contact amigo for a help 1-800-my-amigo
Aug 24, 2012 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Oct 23, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Pride Sundancer 3 Wheel Mid-Size Scooter  Logo
98 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
