Question about Linksys 4-Port CPU Switch 843734000836
Using key bord to change channels
I have a older Linksys Proconnect 4 port KVM switch and I what to use the keyboard to change between the CPU connected the switch. Do you know the Key stocks I should use?
  • Anonymous Apr 03, 2009
    not response in windows hotkey using Ctrl, Alt, Shift in simultenously.
    is there any other clue?
    Scholar:
  • 60 Answers
The hotkeys for switching from one computer to another should be described in your user manual, if you still have it.
According to what I was able to find on the web, it sould be ALT, then CTRL, then SHIFT, then the Computer Number (1 to 4).
Good luck.
Posted on Mar 30, 2008
SOURCE:
How do I select pc using Inland kvm 2 port switch?
Try this
[Scroll Lock][Scroll Lock]1 to switch to computer 1
[Scroll Lock][Scroll Lock]2 to switch to computer 2
There should also be a toggle button next to the mouse ports on the device itself.
Jul 13, 2014 | Linksys ProConnect 2-port KVM Switch
Hi I am having a problem with my KVM2 switch recognizing my MS 2000 keyboard. The Keyboard is usb with the adapter on. It reads my mouse but not the keyboard. I have connected the keyboard directly to...
Once you have plugged the keyboard directly into each unit and have loaded the drivers what you need to do is this:
Plug the keyboard back into the KVM switch.
Now take an extra keyboard, a PS2 if you have one, and plug it directly into the PC and use it to reboot the PC while the other keyboard is plugged into the KVM
(so you actually have 2 keyboards plugged in)
After you reboot if it doesn't install automatically try to install it manually with the extra keyboard
You might have to reboot 2 or 3 times.
Be sure to email me back if you have any more questions orif you need any assistance with this solution. Thank you
Dec 24, 2010 | Linksys ProConnect KVM2KIT 2-port KVM...
What is the hot key
I really wanted to love this switch. However, the best thing that I can say about it is...it works as advertised. Whoa, so what's the problem? Well, the switch has two major problems. The first isn't really Linksys' problem; it's apparent on other manufacturer's switches as well. The switch doesn't support 4th mouse buttons or scroll wheels*. Once the mouse is connected to the switch, those functions are disabled. The Belkin literature (for the OmniView mentioned above) even goes as far to say you should use generic 2-button mouse drivers! While it's not the end of the world, it's pretty frustrating to lose those features.
The other problem, however, renders the switch useless for me. Instead of having to reach for the button on the switch to change PC's, they have built in a keyboard shortcut. Sounds like a great feature right? It would be except that they have made the keyboard shortcut CTRL CTRL. If you hit the CTRL key twice quickly, you will change PC's. The CTRL key?? Why would they choose a key that is used often? I use the CTRL key for firing during games. Imagine what happens when you fire rapidly. Yes, you get the strobe effect as you switch back and forth between PC's! Also, if you use the CTRL key for editing (CTRL C, CTRL V, etc.), an inadvertant double stroke on the CTRL key will switch PC's. This is unbelievable. Unfortunately, the hotkey can neither be changed nor disabled. In contrast, while it is also unchangeable, the Belkin unit uses the Scroll Lock key. This is a much more logical choice because the Scroll Lock is basically obsolete in today's computing experience.
This is some hope, though, because their 4-port switch uses a a keyboard combination of ALT CTRL SHIFT # (where #=1,2,3 and 4). While it is a little more cumbersome, it prevents accidental switching of PC's. Also, the 4-port version has Auto-Scan, which allows you to automatically cycle between your PC's. That option is not available on the 2-port version.
I recommend getting the switch kit instead of just the switch alone. While it doesn't cost a lot more ($18), the SuperVGA cables are worth the price. They are normally $23 each! I tried standard VGA cables on the Belkin switch and the signal degradation was unacceptable. hope that you get the information u need
Aug 31, 2010 | Linksys ProConnect 2-port KVM Switch
I just bought a 2-port kvm switch model no. F1DJ102P (P81551). Can you please tell me the keyboard "hot key" to switch from 1 computer to the other without pressing the button on the KVM unit itself?...
You can conveniently change ports on the Switch through a keyboard command
sequence using the “SCROLL LOCK” key and up and down arrow keys. To send
commands to the Switch, press the “SCROLL LOCK” key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
Apr 09, 2010 | Computers & Internet
Can't switch ports using PC keyboard
Make sure that your keyboard is connected to the keyboard port of the switch. The USB ports on the switch has pictures that indicates where the keyboard and mouse should be connected.
The hotkey combination is CTRL + ALT + SHIFT + Port no.(1,2,3 or 4) + ENTER
Note: "tap the keys one at a time and not at the same time"
Jun 17, 2009 | IOGear USB gcs1734 4-port KVM Switch
I need the combination to toggle between 2 PC.
Scroll lock + scroll lock
Should fix your problem....
In my case, my logitech keyboards don't have a scroll lock...which kinda makes my life harder...
Mar 25, 2009 | Linksys ProConnect KVM2KIT 2-port KVM...
All Keys do not work on keyboard with KVM switch
GCS632U is designed to work with standard USB keyboard an mouse only. You have to make sure that you are not using any type of adapter such as PS/2 to USB adapter. To further isolate the problem, please follow the steps below:
1. Connect the USB keybord directly to th computer to make sure that the keyboard is working properly.
2. Make sure that the keyboard is connected to the keyboard port on your KVM switch. You may take a look under neath this GCS632U (near the USB ports) and you will see an icon where to connect the keyboar and mouse.
3. If you're still gettings the same problem, Try power cycling this kvm switch by disconnecting if from the computers and disconnect also the keyboard and mouse from the KVM switch and leave them disconnected for a minute or two.
4. Reconnect everything after two minutes and then reboot the two computers.
5. If same problem exist, try using different USB keyboard.
NOTE: This KVM swith does not work correctly with wireless, gaming and smart keyboards because it's designed to work with standrd USB keyboard only.
Mar 23, 2009 | IOGear GCS632U 2-port KVM Switch
KVM functionality
This happens on KVMs, some more than others. I have a couple of Avocents that work great with Dell and HP servers, a Belkin OmniView that works great with two Dells and OK with a home built. Bottom line is some switches work better than others just like some PCs seem to behave better than others. If you?re looking for suggestions I would stay away from the cheaper $50 and under switches unless you find a good, used, guaranteed one somewhere. I like the Belkin OmniView and Advocent (really expensive, meant for servers and other medium sized sites). I would stay away from LinkSys, they make good wireless equipment but haven?t heard much good about their KVM switches. The original post was a few months ago so this is really intended to help anyone in the future who is researching a similar problem and winds up here.
Apr 26, 2007 | Linksys ProConnect Compact KVM Switch...
Open Questions:
WEBROOT TechnICal SupPoRt pHone ~II+[[18OO8-O31O69}} NumbEr u.sa//vs Usa WEBROOT USA phone number is ranked #2 out of 2 because 7,728 WEBROOT USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the WEBROOT USA Technical Support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, WEBROOT USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. WEBROOT USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact WEBROOT USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling WEBROOT USA Calling WEBROOT USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from WEBROOT USA Technical Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with WEBROOT USA's Technical Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare WEBROOT USA's phone numbers against each other. Contacting WEBROOT USA in General While I8OO8O31O69 is WEBROOT USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach WEBROOT USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact WEBROOT USA.
Oct 17, 2019 | Webroot Computers & Internet
See all Linksys 4-Port CPU Switch 843734000836 Questions
Linksys 4-Port CPU Switch 843734000836 Logo
161 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
