Question about Lexmark E260dn Laser Printer
I have a large list of envelopes that I have to print, I have tried to put the envelopes in the tray but it won't print unless I put them in the manual feeder. How do I fix this problem?
  • Christopher Thrash May 13, 2010
    What software are you printing from?
  • Official Brand Answer
  • 3,344 Answers
If your printer is the Lexmark E260dn, the tray doesn't support envelopes. The tray is for letter /legal /A4 or A5 paper sizes. For smaller type of media, it has to be fed through the manual feeder. I'm really sorry but I hope I can assist you more on this.
Posted on May 14, 2010
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Mx2300n try to print envelope from bypass tray but error says
Try putting the paper in the 2nd paper tray and then go to system settings then paper tray settings and change to paper for that drawer to envelope and maybe COM10. Then try to print on the envelopes.
Dec 11, 2011 | Sharp MX-2300N Color Copier
How do I print an envelope?
Put the envelope into the fold-down tray narrow end first with the side you want to print on facing up. After you click print in the application click on the 'options' button in the print dialog box and select the envelope size, check the media types to see if envelopes is listed, pick the most appropriate setting.
Aug 21, 2011 | Brother HL-5240 Laser Printer
How do i print envelopes on the HP 1350?
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
Dec 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
Where do you put envelope to print on it?
You are brave trying to print to an envelope...remove paper from tray, put in "plain" envelope, print side down, flap should point to left ( I put a dab of glue stic on flap to hold it securely) will print from top or bottom tray. If envelope keeps coming out askew...make sure to check for a wayward piece of paper stuck in roller from last paper jam.
Aug 04, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Print enevolopes
You are correct. There are no settings listed for envelopes at the Toshiba Interactive Tutorial.
Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
Large envelope printing
If it will fit nto the feed tray yes. you have to go into options when you print and enter the size of the envelope. you may have to enter it as a custom size.
Sep 29, 2009 | HP LaserJet 4650 Color Printer
Can't Print Envelopes, No Ink being used
Set tray 1 for the correct size envelopes in printer properties.
Feb 21, 2009 | HP LaserJet P2015dn Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Lexmark E260dn Laser Printer Logo
309 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
