Question about GE Dishwashers
GE GSD 49290Z04BB dishwasher will not drain - GE Dishwashers
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 13, 2010
  • phoenix594 May 13, 2010
    I have bailed out all the water and checked the drain. No blockage. The drain hose goes up to the garbage disposal and is not blocked at that end.
    What is the air gap?
    We had this problem a few days ago. We checked and found that the drain WAS blocked. Cleaned it all out. The washer ran fine and drained properly for three more loads. Then it did not drain again.
  • Rylee Smith
    Rylee Smith May 13, 2010
    You'll need to clean everything out till garbage disposal and also check the drain line completely for any blockages.
What causes the water to stay running on a ge gsd series dishwasher?
The float is stuck it may need to be replace it is located on the front left side of the dishwasher
Apr 08, 2013 | GE 24 in. GSD1000G Built-in Dishwasher
GSD 4030200 ww
The first thing to check is the drain line that`s tied to your home system. If its not clogged, you may have to check the pump for obstructions such as food pieces or small utensils.
Aug 24, 2012 | GE Dishwashers
I have standing water in bottom of GE GSD 666 dishwasher. I pressume I need to clean screen/filter? How?
I have the same problem, same model GSD660G0322. Have an inch or two of standing water. When I run the drain pump in Service mode, it successfully clears the water. How do I access the filter to clean?
Oct 22, 2011 | Dishwashers
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
GE Profile Dishwasher Mod. #GSD 4430
I have the same problem right now. What is the casue?
Oct 19, 2008 | Dishwashers
GE Nautilus - GSD 4200J00BB
i try to reply to evertone what is it in regards to?
Sep 09, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Dishwasher GSD 4130 Y01WW skipping cycle
i beleive your right id change the timer
Feb 25, 2008 | Dishwashers
Dishwashers Logo
22 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
