I havve a 403T Samsung monitor which when the unit is powered with back power rocker switch a amber light appears and then goes out almost immediately . If I cycle the power rocker switch 2 -3 times quickly the amber indicator will stay on but can not get any functions to work, like the front panel on / off button .I think this amber light is supposed to be green if the set is ok . I have visually inspected the pc boards and can not see any damaged or abnormal looking caps / componets and no sign of burnt traces on pc boards. can you advise me of which pc board is most likly the problem?
  • wheelsss May 14, 2010
    thankx I was hoping for a lazy fix. Larry
  • 12,061 Answers
Http://www.nodevice.com/manual/newmans/403T_CK40pdf/get20938.html
http://www.givemefile.net/smanuals/monitors/samsung/file/36982.html
OK above please find a user manual and below that a service and repair manual, this is what the engineers use to troubleshoot and hopefully repair.
Troubleshooting say if it is shutting down, after a certain amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. Now just replacing boards will most likely just end up with more faulty, boards, as related you MUST ensure that you have the cause of the event, before we change anything. I have seen so called, "Techs" replace every board, and virtually every component, and that STILL didn't fix it, because the "Fault, or Cause" lay elsewhere, and had not be repaired FIRST, you see that FIRST STEP, like everything in life, is, CRITICAL.
Posted on May 14, 2010
  • 6,993 Answers
the amber light is supposed to turn green when the monitor receives signal from the CPU. We need to know where the fault is coming from, if its from the Monitor or the CPU.
First, connect another confirmed working CPU to your monitor and if there is a display on the monitor, then it will be certain that the fault is not from your monitor and if there is no display, then the fault should be from the monitor.
If the fault is not from the monitor, then you need to troubleshoot your computer/CPU.
Check the VGA cord that connects the CPU to your monitor, Check the VGA card on the CPU's motherboard, if it is well fixed.
Check your motherboard RAM (memory). If the RAM is not well fixed or dusty, there will be no display. Remove the RAM from the motherboard, clean the RAM and RAM slot.
Also, check your motherboard processor, remove it clean it and return it back, just as you did for the RAM, because the processor also can make the CPU not to display on the Monitor.
If after doing the above and the problem is not still solved, then your motherboard is the one that is causing the problem, you will have to get another motherboard, as it is rare to repair motherboards.
I wish you good luck.
Posted on May 13, 2010
  • wheelsss May 13, 2010
    Are you familiar with this particular unit?? It is more like a tv than a computer monitor . Without the unit powering up to a green light on the front panel you can not select one of the several inputs . ia rca ,s-video dvi etc . please respond back ;
  • Walesarumi
    Walesarumi May 13, 2010
    I'm sorry, I didn't know it wasn't exactly a monitor, I mistook it for normal computer monitor.
    The best I can provide for you now, is the service manual of your monitor. I believe the service manual should be able to guide you on what step to take in resolving the problem. Note that the service manual is different from the user manual. The service manual is for troubleshooting and repairs.
    Visit:http://www.givemefile.net/smanuals/monit...
    Scroll down the page a little bit and you will see "Download Samsung service manual 403T repair manual".
    Enter the code above it before you click the download.
    If this does not please you, you can simply ask the next available expert.
    Good luck.
Systematic diagram for samsung syncmaster 403t
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Schematic diagrams to power regulator board to many popular TVs are given. Here I can't attach it, as all of it are in PDF format.
Jun 25, 2014 | Samsung SyncMaster 403T 40 in. LCD...
Screen loses power frequently. Comes back on by itself
If it does comes back on by itself, make sure that the vga cable is properly connected on the vga port on your computer. Does the led light on the monitor turns from green to amber? if yes, check for connection cables and the power cable.
Please let me know how this goes. Thank you for using FixYa.
Jan 20, 2011 | Samsung 2243BW Monitor
Samsung 403T no power
1) Fuse is good?
2) You must have 5vdc stanby voltage the minute you plug the set into the wall, this is a must have before going further. Please look for that first, then report back what you find. Pictures and Sch will be a great help. See example of my pictures here: http://s807.photobucket.com/home/budm/allalbums
Jan 27, 2010 | Samsung 403T 40" LCD Monitor
Samsung 403T 40'' monitor has no power. (CK40PSNB)
FYI, I have found the real solution for this issue with Samsung 403T. It is a design flaw which leads to this problem after a while. Luckily, it can be easily corrected, but it requires medium soldering/electronics skills.
Anybody interested in how to fix it feel free to email me and I'll provide you with the solution. Please make sure that the symptoms of your monitor are exactly the same with the ones described above.
Mar 25, 2009 | Samsung 403T 40" LCD Monitor
Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Monitor doesn't work
I'd try this monitor on a spare computer. It sounds like the video card (motherboard integrated or otherwise)is not putting out any video information or missing sync signals. The monitor must receive these signals or it will go into standy/sleep mode. If the computer has integrated (on motherboard) video, check your bios settings to see if it is properly enabled. If it has a slot video board, then try a different video board. Your present board might be dead. Another possibility is a bad cable connection. check the connectors for bent pins. Assuming the connector is the standard HDB-15, it is easy to bend a pin over.
May 30, 2007 | LG L1730S 17" LCD Monitor
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
