Question about Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops
Laptop doesn't start when power cord is plugged in
My laptop startup problem occurs only when the power cord is plugged in. Press the power button, the little green light goes on and there's just a bit of sound, then all goes silent and no startup. I hold the power button for 10 seconds to turn off the little green light, unplug the power cord, and then it will start up in battery mode, after which I plug in the cord again. This happens 80% of the time. Sometimes it will start up when the power cord is plugged in, but usually I have to disconnect it first. Does this mean there is something wrong with the power cord? Very puzzling.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
More than likely the charger is bad
Posted on May 13, 2010
Testimonial: "Can't say for sure if this is the solution until I change the charger, but it sounds logical ans is sure worth a try. Thanks! "
Error 2000_0333
When does this error occur?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 30, 2012 | Dell Inspiron 15 Laptop
Hp g56 startup
Will,
It sounds like the LCD on your screen may have burned out. Here's a few things you can try to verify if that is indeed the case:.
1. Unplug the power cord and take the battery out of the laptop. Then, press and hold the power button in for at least 30 seconds. That will drain the residual power from the system. Then, plug back in only the power cord - the battery should still be out, then try to turn the computer on. See if any video occurs at all. If the screen is entirely blank after a few minutes, go ahead an unplug the power cord again to turn off all the power to the unit.
2. Put back in the battery and power cord, and plug an external monitor or projector into the laptop. Turn the laptop on and then close the lid immediately after pressing the power button. See if any video will appear on an external video source. (IE monitor or projector). If video does show on the external monitor, then open the LCD screen back up and see if any video shows there.
3. If the video does not show on an external monitor at all, try the hot keys/function keys to swap the video output. (On your model of laptop if should be the F4 key.)
4. Also try the screen brightness keys. Press and hold F3 to increase the brightness on your laptop.
If these steps all fail - then most likely, the LCD is dead. You will need to either call HP to set up a return to depot repair - or contact a certified technician to repair the laptop for you. The number to call HP is: 866-234-1377. (This can be expensive if your laptop warranty is expired.)
I hope this helps you out!
Nov 22, 2011 | HEWLETT-PACKARD G56-129WM Laptop PC
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
Hi, how to resolve ibm thinkpad t43p on startup with black screen
It could be a faulty battery. Remove the battery & try to power up the laptop.
If the laptop did not power up after removing the battery, then notice the power receptacle where you plug the power adapter's cord to the laptop. While plugging the power cord in, notice if there is a spark occurring at the power receptacle. If the spark occurs, then disconnect internal drives & connectors one at a time until subsystem with short is identified. If power input still a short with bare motherboard, replace the motherboard. If the spark did not occur, then inspect the boards for burnt or melted components, cold solder on DC jack, open connections, or unseated cards.
Feb 10, 2011 | IBM ThinkPad T43 Notebook
Will not start. HDD power light comes on for about 5 seconds, then goes out. I put it on standby, started again, and put back on standby, has not come on since.
Feb 06, 2011 | Toshiba Satellite P105-S6084 Notebook
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
I turn on the power, the power light comes on and the hard drive light for about 3 seconds than off...and i never get a screen. what could be the problem
Hello
First Remove all power (adapter power Cord and Battery (for laptops))
Hold down the ON button for 30secs (dispersing internal voltage)
Plug the power cord in only (ie leave battery out, for the moment)
Turn on
If it worked replace battery.
If it doesnt
Start your computer and press down on the "F8" key to get into the "Advanced Boot Options" menu.
Click the "Repair your computer" option on the menu and press the "Enter" key.
Select your keyboard layout from the choices given.
Click the "Next" button to enter the "System Recovery Options" menu.
Choose "Startup Repair" from the menu and press the "Enter" key to start the repair on your startup disk.
Dec 15, 2010 | Toshiba Satellite A135-S2386 Notebook
My HP Pav laptop just died (shut down on me) and wont turn on
1.remove the battery and disconnect the power cord from the laptop. 2.hold down the power button for 1 minute 3.now connect it only to the power cord.keep the battery away 4. as soon as you press the power button to turn it on, keep on tapping F8 key. 5. If you see advanced option, you can choose safe mode with networking and it hit enter. 6. now remove the security like Norton or macafee and scan it with malwarebytes(www.malwarebytes.com) 7. Now, restart the computer 8. If data is not important you can restore the computer to the factory setting, but all of the data would be lost. 9.to restore the xp computer start press F10 at the startup 10. to restore the vista computer start press F11 at the startup.
Dec 08, 2009 | HP Pavilion dv9000z Notebook
Dell 1555 not powering up. Solid white light shows on startup button but thats it, no keys function screen is devoid of life. Even the Optical drive eject button will not respond. Can anyone help? Dudsmith
Try removing the battery , and the power cord, and making sure the laptop is off..
Then press and hold down the power button for one minute firm..
Then put the battery back in, then plug the ac cord back in, then try to turn it on..
Oct 30, 2009 | Dell Studio 15 Laptop
Black screen
Yeah, HP has some major issues with their power management system on their boards.
Aug 24, 2008 | Dell Latitude D600 Notebook
Lenovo 3000 N200 Intel Pentium Dual Core T2390 1.86GHz Notebook Laptops  Logo
174 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
