HELP NEEDED! When turning TV on, there is no picture, light flashes red three times, then TV turns off. I also need to replace the screen because someone decided to use an abrasive to clean it. HELP!
  • kdsigg Mar 30, 2008
    Model: Panasonic 53TW53G
    screen size = 26 X 46
  • 8,617 Answers
Need to know the model number as I have access to many different screen assemblies and also the 3 flashes is most likely a diagnostic code, so if you post the model number I will be able to help you out with both problems.
Posted on Mar 29, 2008
  • Sonny Berry
    Sonny Berry Mar 30, 2008
    First of all 3 blinks means your convergence ICs have shorted out you will need to replace them. Yours should be STK392-110 or 120 replace both of them. I will include a link where you can order the ICs and they include free step by step instructions on how to install them yourself instead of paying the 300 or 400 to a shop. The job only takes about an hour from start to finish. plus they give unlimited support so you will be able to do the repair properly. Heres the link. you will find them under the heading "Convergence IC "
    http://servicemanuals.vstore.ca/
    Now if you measure your screen I will check and see if they have a screen for your set . Just need the heigth and width
  • Sonny Berry
    I will check on the screen size in the morning and repost when I find out if theres one.
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Power light flashing three times. when came on screen was distort
very common problem you need to replace the flyback number 259296 and the CP150 you can get replacemnent flyback and cp150 at the following link with free step by step instructions on how to do the repair.
Mar 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns off and on
The first time my lamp needed replaced, the red light came on as well. This time my tv did the same thing, but after talking to my tv repair man he thought it was the lamp. He said that if you use your tv often then the lamp probaly needs to be changed after two or three years. I replacedmy bulb and it corrected the problem and I MUCH BETTER PICTURE.
Dec 29, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony KV-35S66
power supply kit hozout plus flyback 1fuse 1restor
Nov 10, 2008 | Sony KV-35S66 35" TV
Olevia Kolin PT-501 LCOS TV Screen remains black and lights flutuate
I have the same TV and had the exact same problem. I had to replace the lamp and power supply in mine to get it to work. Unfortunately...its next to impossible to find the parts, at least the power supply. I found the lamp online and I was lucky to get the online store I purchased the TV from to send me a power supply from one of thier stocked models, but only after I turned them into the FTC Consumer Protection. The TV was sold to me as a closeout but new, as it turned out the tv was a refurb, thats the only way I could get the parts I needed.
Hope this helps and if you need any other information please let me know.
T
Nov 07, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
Red Light Flashing 6 times
When the lamp fails in this unit, often the thermal fuse opens. The error code is 6 blinks. To replace this part requires a great deal of deal of disassembly.
Mar 29, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
