Question about Sony Playstation 3 (PS3) Console
How do i reset my PS3 to factory settings?? - Sony Playstation 3 (PS3) Console
    President:
  • 548 Answers
Take a look at this: http://www.youtube.com/watch?v=sWOrYLX01eA
If you need further assistance, just leave a comment. Cheers
Posted on May 13, 2010
Cant sign into playstation network after factory reset
Doing a factory reset will clear your network settings and sign you out of your account. If you are connected to the internet using wi-fi make sure to get that setup again before trying to sign back into play-station network.
Video:
How to connect ps3 to wifi
Sep 05, 2016 | Sony Playstation 3 (PS3) Console
Playstation 3 reset
Go into your setting and there is a setting for factory restore it will wipe everything on your PS3 back to how it was when you orginally bought it! It's located in your settings section near the bottom, it will walk you through the process after you click yes to reset your PS3.
Jan 06, 2014 | Sony Playstation 3 (PS3) Console
Reboot playstation 3 to factory default
go to settings on the dashboard and the option to reset to factory settings is at the bottom
Jan 27, 2012 | Sony Playstation 3 (PS3) Console
How do you reset your PS3?
You can reset the Sony PlayStation 3 to troubleshoot the gaming system or restart after a hard drive freeze. Resetting the PS3 will restore the PS3's settings to to the default factory settings. Consider backing up any data or custom settings before doing a system reset for the PS3 as they might be erased.
instructions:
  • urn off the PS3 by flipping the power switch on the back of the system.
  • 2
    Turn the power switch back to the "on" position.
  • 3
    Hold the power button while the PS3 is powering up until you hear three beeps. These signal that the PS3 has received the manual system reset command.
  • 4
    Prompt through the initial setup menu to continue resetting the PS3.
  • 5
    Select "Format" from the system menu to format and finish a complete system reset for the PS3.
  • Dec 06, 2011 | Sony Playstation 3 (PS3) Console
    PS3 freezes when it gets to a certain point after you select a user.
    I would say try a factory setting reset. There are several videos on youtube that tell you how to enter "safe mode". Just follow any of those steps, and do a file check first, then restore to factory settings.
    Mar 21, 2011 | Sony Playstation 3 (PS3) Console
    VERTICAL BLUE LINES ON PS3
    You could try a video reset on the ps3 or a factory reset. The factory reset will erase all data on the unit, the video reset will now.
    The video reset is done by pressing and holding the power button for 3-5 seconds from a power off state, the unit will beep 1 time indicating the video is reset.
    Here is how you do a factory reset:
    This will wipe all the saved games and data from the machine but I have found it to correct most issues with the ps3.
    You will need to push the power button to turn on the unit, but keep the power button held down for about 30 seconds. You will hear a beep (resetting the video settings), then 2 more beeps. After the 3rd beep you can let go of the power button and it should take you to the set up screens like you just got it out of the box.
    You will lose everything you have saved doing this but it seems to make the system run just like out of the box again. If this does not fix the problem then it most likely is a hardware issue and may need serviced or replaced.
    Feb 13, 2011 | Sony Playstation 3 (PS3) Console
    Long story short. family member died, got his PS3, cant create a new PSN account because i don't have the master account details. is there a way i can obtain the master account or reset everything to make...
    PS3 reset to factory settings.
    Power On. Then press and hold until it shuts down again. Now press and hold the power button until you hear....1 beep..... then 2 beeps....release. This will put you in the service mode. Select option to reset system to factory settings.
    Oct 29, 2010 | Sony Playstation 3 (PS3) Console
    Nothing shows on screen when inserting game , i hear the disc is turning but nothing shows on screen
    Make sure you have the cables hooked up properly, regardless of whether your using an HDMI cable or regular A/V cables.
    Best thing to do in a case like this is to do a factory reset on your PS3. Be sure that the A/V cables are being used originally and are hooked up properly.
    Here is how to do the factory reset on a PS3:
    1 - Turn on TV and set input to port being used.
    2 - Make sure PS3 is connected via correct cable.
    3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
    Try that, if you still don't get video and you know the cables and the TV are set to the right output then its an issue with the main board not having any output.
    Apr 22, 2010 | Sony Playstation 3 (PS3) Console
    How do i reset my ps3
    To reset the PS3 to factory setting, do the following:
    • On the PS3 Menu go to Settings > System Settings > Restore PS3™ System and click yes.
    This will have fully restored your PS3.
    Oct 29, 2009 | Sony PlayStation® 3 (60 GB) Console
    My PS3 was loading discs just fine, but now it doesn't
    Have you tried backing up the PS3 and Factory reseting it? To back up follow this guide: http://manuals.playstation.net/document/en/ps3/current/settings/backuputility.html
    To factory reset:
    http://www.tech-recipes.com/rx/2265/ps3_how_to_factory_hard_reset/
    Aug 12, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    312 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
