Question about Cell Phones
I m not able to connect my c5212 with net , it gets connected to pc but after the net gets connect it stops after recieving 231 bytes of data.. can anyone help me regading this kindly mail if u have the sollution .pc suite dosent connect the mobile to pc for internet sunil.talkto@gmail.com
    Problem Solver:
  • 10 Answers
Try punching some random guy in the street to take your anger out.
Posted on May 13, 2010
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
Lap top not getting data from j1708 connection
There may be a problem with connectivity;
The protocol is basically 8N1 serial, but messages are separated from each other using an idle timeout (minimum 10 bit times - at 9600 baud this works out to be 1.25milliseconds). Messages consist of one message identifier (MID) followed by one or more data bytes and a checksum byte. The checksum should be the two's complement of the eight-bit sum of the MID and all the data bytes (a message is considered valid if the eight-bit sum of all the characters including the MID, data bytes and checksum is equal to 0). The total message length cannot exceed 21 bytes.
You cannot connect this directly to your PC without at least an RS485 to RS232 converter - you can get away without the pull-up/pull-down resistors for testing but should ensure that any termination resistor is open.
Hope that helps.
Dec 03, 2013 | Computers & Internet
I want to connect my samsung c5212i to laptop for net connection but i didn't get any software from company,how can i get access to net?is any software is available?
You have not declared your Operating System (like Windows XP, Vista etc.) anyways I hope that the following link will help you to download the Samsung usb driver software.
http://www.software112.com/search-program/1/samsung+c5212+usb+driver.html
Good Luck!
Mar 04, 2011 | Computers & Internet
Sir iwant downlod samsung c5212 usb driver wichh site avleble conect mobile to usb leptop internet my leptop pc studio instol but usb driver not fond p/l help
Hey Plz download Samsung Pc Suite over the internet from google than buy a USB cable of the samsung c5212 and get connected to internet
Aug 02, 2010 | Computers & Internet
Im looking for a usb installer of c5212 . my pc cant read the datas of my cellular phone c5212 once i connect the usb cable to my pc
I bought usb data cable PCBS10 for my Samsung C5212, I installed CD but still it shows that mobile not connected.
Jul 04, 2009 | Samsung Cell Phones
Samsung c5212 has 18000007
If you have tried to unlock handset? All those 00000 arn't good. Any error to that affect requires a service centre to re-flash handset & re-load software (if at all recovrable)
Jul 03, 2009 | Lands Phones
I own a D Link DSL-G604T Wireless Modem. When i connect through any other modem, the connection is perfect, but when i attempt connecting through D link, all appear okay, including diagnostics and port...
Go into control panel network connections and make sure it is active and not disconnected in there. Sometimes they disconnect and you may find it is an install problem. If it says that it is connected uninstall and reinstall software and see if that helps the only other thing I can think of without seeing pc with this info is it maynot be fast enough for your net connection what sort of net you runnig through it? speed
Jul 26, 2008 | Computers & Internet
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
