Question about Breadman TR444 Bread Maker
The spacer ring under the paddle got brittle and fell apart.
This caused the dough to ooze through and seize up the rotor. Am I
making sense? Can it be replaced or is the machine done in.
Model number TR444 It's an old model - given to me recently - just
started using it after many years of disuse.
Richie_asg1
  • 1036 Answers
SOURCE: need dough paddle and instruction manual Welbilt DM2000
Instruction books for sale cheaply here -
http://cgi.ebay.com/DAK-Welbilt-Breadmaker-Bread-Machine-Manual-Recipes_W0QQitemZ320263370263QQcmdZViewItem?hash=item320263370263&_trkparms=39%3A1%7C65%3A10&_trksid=p3286.c0.m14
Dough hook also here -
http://cgi.ebay.com/WELBILT-Bread-Machine-Dough-Blade-Paddle-Dak-100-etc_W0QQitemZ140241244639QQcmdZViewItem?hash=item140241244639&_trkparms=39%3A1%7C65%3A10&_trksid=p3286.c0.m14
I think this will be cheaper than the manufacturers prices.
If this helps you at all , please rate as Fixya..
Thank you.
Posted on Jun 14, 2008
  • 204 Answers
SOURCE: Need dough paddle for Regal Bread Machine K6725
Try http://breadmakerpartsemporium.ioffer.com/ They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 09, 2009
  • 204 Answers
SOURCE: Missing the dough paddle
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices, probably will be around $10.
Posted on Jan 11, 2009
SOURCE: Excessive wear between paddle and panshaft?
You can drill and tap the paddle, where it faces the flat on the shaft, and install a small setscrew. Something like a 10-32. Make sure you use a nylok screw or use a thread locking compound (available @ auto parts stores) to prevent the screw from working loose and getting into your bread! Just tighten the screw enough for a snug fit so that it can be removed for cleaning.
Posted on Feb 14, 2009
SOURCE: kneading paddle for breadman tr444
Call Breadman Products 1-800-223-9054.
I had the same problem and they solved it.
Sincerely
Maria Kalotay
Posted on Mar 16, 2009
The spindles that you attach the paddles to is leaking a black lubricant or something like that. I was making a simple sweet dough. By the way, I NEVER bake in the bread maker. I only use it to knead the...
Your machine has a lubricating grease that is under the small gasket or washer at the bottom of the pan under each paddle. After a lot of use the little gasket can fail and the grease can get get past the gasket and into your bread. The best thing to do is either replace your pan with what is called a "pan assembly which will include everything but the paddles. If you decide to do that be sure to keep your paddles. The other choice of course is to replace your machine which might not be a bad idea if your machine has been used a lot because you would have a new pan assembly but older parts may begin to fail such as the drive belt. Bread machines aren't all that expensive anymore so you may want to go ahead and replace especially since you just use your machine for making dough.
Feb 08, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
My bread maker quit working. The blade doesn't move to mix the dough
I expect the teeth are stripped on the plastic drive shaft or the motor has seized.
Time for a new one I guess.
Jan 31, 2011 | Microwave Ovens
On dough mode, machine won't knead
paddles could be slipping. that was my issue. Here's the solution if so.
What happened in my case is that the nut holding the rotor that drives the left paddle was loose, allowing the paddle to slip. Only one paddle would knead and mix. The belts in my machine are fine, in fact so massive I can't imagine them breaking. But access? Yikes.
So, forget the screws on the bottom. They just hold on the feet. Remove all the screws around the top of the baking chamber, the two that hold the control panel on, and the remaining screws under it. There are about 12 screws. Remove the 6 at the bottom of the baking chamber, but not the 2 that hold down the element. Remove the metal sides of the baking chamber (it's one piece). All this is to get access to the screws that really hold the works to the base. They're around the perimeter of the metal chassis on which the motor and element are mounted. Remove them (get help or arrange something to keep the control panel from exerting too much pull on the wires to the element. You could unplug the control unit but I didn't need to.)
Once you lift the motor assembly exposing the belts underneath, you'll see what's loose. Each nut holds down a metal plate beneath the rotor. If it gets loose, the rotor can move more or less freely and won't turn. It looks like they applied an inadequate dab of glue to hold those in place. I should have put in a star washer to keep the nut from loosening again. Next time.
Good luck getting all the screws back in the right places ;-) Machine works fine now.
May 27, 2010 | Zojirushi BBCC-X20 Home Bakery Supreme...
First time use. set machine to dough and pressed
Hi, Keep the bread pan out of the machine and start a kneading cycle. Look through the lid window and see if the motor shaft is turning. If no...then the belt fell off. If the motor spins, check to make sure the paddle spins freely. Keep pan out and turn paddle by hand. If no then the bearing is frozen. If that's ok..make sure you inserted the pan correctly into machine. If everything checks out then it's a faulty machine. Before you do anything send it out for warranty service. Usually it's warranted for a year. Hank
May 12, 2010 | Black & Decker B2250 Bread Machine
I have a Breadman Model: TR845. It seems that the gear in the actual machine that turns the knead paddle is striped. It turns when the pan is empty ... so I know it is working, however with dough inside or...
I had the same problem with my Breadman TR845 that I bought used at Goodwill. I made my first loaf O.K. then could not get the knead paddle to turn except when the pan was empty. I took it apart and discovered that the timing belt (flat belt with integral teeth) had slipped off the black plastic gear attached to the shaft of the motor. The belt was still around the shaft of the motor which allowed it to move the paddle only when empty. I needed a small spacer washer that would keep the black plastic gear from sliding on the shaft and allowing the belt to slip off. There is a lip only on one side of the plastic gear so it if moves the belt can slip off. I created a spacing washer from the cap on a tube of toothpaste. I cut the cap in half and had to use a metal file to get it the right size. I needed to be 1/4 inch tall and 3/4 inch in diameter. I cut the spacer so that I could slip it over the shaft. After putting it all back together everything works fine. And the toothpaste tube was almost empty anyway.
P.S. There are lots of screws that hold it together and the belt and gears are at the bottom of the Breadman and you have to take the whole thing apart to get to the bottom. I was able to leave all the wires attached so that putting it back together went quickly compared to the work of taking it apart.
Steve S.
Apr 27, 2009 | Breadman TR845 Bread Maker
Dough paddle is jammed on Welbilt ABM 4000 Bread Machine
Put boiling water into pan and leave until it is cool to the touch and try wiggling the blade free.
Oct 26, 2017 | Kitchen Appliances - Others
The paddle will not stay on the shaft while mixing dough.
Probably the paddle and shaft are worn. Both are replaceable. Buy a new Paddle and a Kneader mounting shaft unit (Part No. ADA 29A115)
Panasonic Parts
National Parts Center at 800-332-5368 between the hours of 9:00 a.m. and 8:00 p.m. EST Monday through Friday.
Nov 16, 2008 | Panasonic SD-YD250 Bread Maker
Makes a bad loose sound when mixing dough
My Breadmakers Hearth was making the same sound, so after taking it apart I found that it was only the Bread Pans "under paddle" that the machine reaches up and connects to to drive the Paddle. I wears loose and wobbles and starts to slip making that banging sound. You can either replace the Bread Pan or like I did INVERT the under paddle (requires removing the C-clamp washer) to extend the life of the Pan and use of the Hearth. Hope this helps you.
Oct 20, 2008 | Toastmaster Breadmaker's Hearth 1193 Bread...
Breadman TR444 Bread Maker Logo
21 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Irene Tulloch
paul
paul
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
