Question about Craftsman 118 pc Dual Marked Mechanics Tool Set
What is the initial setting tor air/ fuel mix.?
Having trouble ideling.
    Brigadier General:
  • 4,088 Answers
Check the air cleaner, muffler, and fuel filter for any plugging. Check the fuel lines for condition. Make sure the carburetor fasteners are tight. If all are ok, then set the L needle CW to it's stop (lightly), then back out CCW 1-1/2 turns. Start the engine and allow to warm up, then turn the needle CW until the engine runs fairly well, but allows the engine to 'follow the throttle'. Set idle speed screw so that the chain stops moving, but the engine continues to run. Hope this helps!
Posted on May 14, 2010
Where is the air/Fuel ratio control located in Toyota corolla 2011?
car needs to be on a dyno to adjust air fuel/ mix correctly/
its on the throttle body
fiddle with it air fuel mix on an EFI it will get you more trouble
go for the fault codes to see what sensor is the problem
most likely the 02 sensor
Jan 22, 2017 | Toyota Cars & Trucks
Does 1984 25hp johnson at tor need 2cy oil mixed wiyht gas
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Sep 23, 2014 | Seloc Johnson Outboards 2002-2007 Repair...
I have apolandpro46cc 20inchchain saw it will start but it cuts off and will not idle
In sequence:
First, if it has a "torch" plug, toss it. Go for BM7A NGK.
See that nothing has come loose- carb & thereabouts.
Dump fuel & put in FRESH mix.
Carb may need adjustment.
See that ignition switch lead and switch are not intermittently shorting.
If all else fails, do a vac/press test- could be crank seals.
More info up front makes it simpler.
Jun 27, 2014 | Poulan Pro Chain Saw 46cc 20"
1990 BMW 525i stalling, ruff idel.
Your fuel injectors maybe clogged up,have them cleaned.
Apr 25, 2017 | Cars & Trucks
Idel problem which causes the car to always switch off it doesnt have a constant idel
hi ,look at the big black pipe under the bonnet that goes from your air cleaner box to your fuel injection system ,(note its the biggest plastic pipe under there usually ) this will have a split or crack in it somewhere ,have a good look over it ,maybe even remove it if you or someone can ? replace it if you find its split ,if you cant afford to do that then you can wrap thick adhesive tape around it many times to block the hole ,this hole is an air leak which is confusing your cars air and fuel mix computer brain ,THANK YOU for using FixYa
Feb 02, 2011 | 1999 Volkswagen Golf
HAS A DEAD SPOT JUST WHEN I TAKE OFF RUNS FINE AT IDEL AND RUNS FINE WHEN YOU OPEN IT UP
Hi and welcome to FixYa,
Initially, inspect the burn colors of the sparkplugs. If they are very light in color, then it would indicate a lean mix
Offhand, a lean mix and the flat spot would both indicate an air leak; too much air, too little fuel. Either or both could be caused by a torn or out of position air filter or the air box not properly sealed. Aftermarket free air breathers/filters such as those by K & N and/or non-stock exhaust could also cause lean mix/flat spot if the carbs were not re-jetted. In some instances, the needle height might require adjustment.
Good luck and thank you for asking FixYa.
Apr 07, 2010 | 1994 Yamaha XV 535 Virago DX
Rebuilt carb need air and idel mixture screw settings. Blower runs but only a few seconds and then will not restart.
air fuel mixture screw shoould have initial setting of two turns out from lightly seated,check unit make sure cylinder is tight to base they only have two screws holding them down,if 2 cycle motor has a vaccum leak they will not run properly,also check compression if you have gauge should have a least 100 psi to run properly.
Oct 01, 2009 | Homelite 'Yard Broom' Leaf Blower
Idel adjustment on fuel injected road king.\not on
Thats not totally correct. remove your air filter cover. look to the lower right side. You will see a small hole thats where the screw driver goes in to adjust your idle. Ya the dealer has a scanlizer that can also do it if u want to spend the bucks.
Sep 03, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
Daewoo lanos 2000
correct operation due automatic air-fuel mix adjust by engine temp sensor check this sensor please ....
Oct 18, 2008 | 2000 Daewoo Lanos
Craftsman 118 pc Dual Marked Mechanics Tool Set Logo
78 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
