Question about HP Office Equipment & Supplies
HP 3600 Color Laser Printer is prnting in all black pages instead of color. Black Print comes out white on black pages I has been Printsing in color until yesterday
    President:
  • HP Master
  • 2,923 Answers
First, make sure that the colored cartridge is not empty. If you verified that it's not empty, try to remove the colored ink cartridge, clean it, then re-seat the cartridge back to the printer.
If same problem occur, restart the print spooler. Here's how:
Start > Run or Search > type "services.msc" (without quotes).
Locate and click the "Print Spooler" and make sure to high-light it in Blue.
Then click on "Stop the service", followed by "Restart the service".
If same problem occur, uninstall the driver and reinstall it. If that did not help, replace the ink cartridge.
Thank you and good luck!
Posted on May 13, 2010
Which is the best printer copier
Depends on if you want color or black and white, how many pages you are going to print. If you want color, look at one of the HP X series inkjet units, cost per page way lower than laser. If you are looking only black and white, small office I would buy an HP M425.
Sep 06, 2014 | HP Office Equipment & Supplies
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My HP Color LaserJet 3600 prints nothing but black pages. All cartridges seem OK.
Check the printer properties and see if it isn't set to print black and white only.
Mar 14, 2011 | HP Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Out of magenta toner, but need to print in black
normally most printers when you select properties and advance you can select the quality of printing there you can select grayscale instead of color that will do it
steps
click start printers right click properties for pinter select advance change the settings. print a test page will come only black if not repeat steps.
Jul 26, 2010 | Xerox Phaser 7300DN Laser Printer
Lexmark Z705
In the printing preferences you need to select Black and white.
1. open the document you want to print
2. click file
3. click print
4. select printer from list, then click on preferences
5. look around the pages.
In Color tab I found a print in Grayscale - this setting will print the document in black and white colors, the pages may be diffrent on diffrent printers. look for black and white setting or Grayscale.
picture: printing preferences, color page on a hp printer, select grayscale with black cartridge only.
May 19, 2009 | Lexmark Z705 Inkjet Printer
I just got a hp photosmart c4480 printer and it makes black and white copies, but I can't figure out how to print in black and white like when I am on a web site.
OK, Whe you select Print from the File Menu and the Print window opens, selct the Color tab.
There should be an option to Print in Grayscale. Check the box beside it and click OK at the bottom. Then back at the Print window, click Print.
(Note: If this option is not on the Color tab, or you do not have a color tab, look on the Advanced tab for the same thing.)
Need additional help...use the Comment link.
Thanks for using Fixya.
Apr 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Internal test page fine, external prints black in blue
before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Jul 12, 2008 | HP DeskJet 845c Printer
35 people viewed this question
Seeker5211
Seeker5211
