Question about Dishwashers
Dishwasher is not cleaning well. I've scrubbed
Dishwasher is not cleaning well. I've scrubbed the entire interior, ran vinegar, rinsed dishes, still not working well. What else can I do?
  • Dishwashers Master
  • 43,501 Answers
Leaving a white residue on dishes after its full cycle. Have tried different soaps,rinsing agents, and ran it through a cycle with a cup vinegar in it.Is there something I can do to repair this problem ?...
As you have already done the vinegar cycle and all now it must an technical reason.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Mar 17, 2011 | Frigidaire Dishwashers
Why are the coffee cups still stained after the dishwasher is finished, but all the other dishes are clean and santized
Coffee stains are just one of those things that your dishwasher just isn't going to remove. I assure you they are sanitized and safe to use. That being said there are some things you can do to remove the coffee stains.
Use a damp cloth to scrub out the inside with baking soda. Soaking overnight with hot water and baking soda may also work.
Soaking in bleach or vinegar over night. It goes without saying but make sure you rinse your mugs well if you decide to do this.
Fill with boiling water and a tablespoon of dishwasher detergent soak overnight.
Scrub with a paste of corn starch and vinegar. Leave on for 30min - 1hour and rinse.
Interestingly enough denture tablets have also been known to remove coffee stains. Toss a few in there and soak overnight.
Feb 28, 2011 | Frigidaire Professional Series 24 in....
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
    Instructions Things You'll Need:
    • Vinegar or lemon juice
    • Gel dishwasher detergent
    1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
    2. Rinse aid in solid form
      Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
    3. Vinegar or lemon juice
      Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
      After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
    4. Gel dishwasher detergent
      Switch to a liquid or gel dishwasher detergent. Any brand will do.
    5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
      Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
    Feb 02, 2011 | Dishwashers
    Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
    Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
    Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
    Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
    To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
    Aug 29, 2010 | KitchenAid Dishwashers
    My Frigidaire dishwasher is leaving soap, a lot of soap, on dishes under where the dispenser dispenses. It just started hapening. Also, it has always left a light film on the clear glasses.
    I scrubbed the screens with a brush and added two cups of white vinegar to the bottom of the washer, then ran it. Cleaned up nicely. I most likely will add a cup of vinegar once a week.
    Sep 13, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
    Rinse agent won't dispense in Maytag dishwasher
    The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
    Apr 10, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    Put rinse liquid detergent in dishwasher rinse aid compartment.
    I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
    Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
    1. Get some white vinegar--I used nearly a quart.
    2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
    3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
    4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
    5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
    6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
    7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
    8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
    9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
    10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
    11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
    I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
    Takes some patience but hey, beats a big repair bill!!
    Apr 04, 2009 | Kenmore Dishwashers
    Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
    check to make sure your lower spray arm openings are not blocked.
    Nov 07, 2008 | Dishwashers
    White Residue
    most likely it is your detergent. palmolive eco is notorious for leaving a white chalky residue on dishes. try this out before calling a service tech: put unclean glasses in the dishwasher and in your soap dish and rinse cycle cup put 1/2 cup of distilled white vinegar. if it cleans (or improves) your dishes, then your detergent is the culprit.
    Jul 29, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
    Dishwashers Logo
    53 people viewed this question
    Top Dishwashers Experts
