Question about Amana NDE2330AY Electric Dryer
Makes a squak noise
When on it makes a squak noise it get louder
    Top Expert:
  • Amana Master
  • 76,630 Answers
You need to replace the dryer belt.
Instructions Things You'll Need:
  • Screwdriver
  • Amana dryer belt
  1. Step 1 Disconnect the power source from the dryer. You can unplug from the wall outlet, remove the fuse from the fuse box or flip the breaker in the panel box.
  2. Step 2 Pull off the front panel of the dryer. Remove the screw in each corner at the bottom of the dryer's front panel. Lift up the front panel until the two clips at the top disengage. Remove the two screws that are found beneath it at the corners to remove the cabinet top.
  3. Step 3 Remove the belt by releasing the tension applied by the movable idler pulley wheel. The belt loops over the drum, under the idler pulley wheel and then around the motor's drive pulley.
  4. Step 4 Discard the used belt. It is fine to just throw it in the trash.
  5. Step 5 Install the new belt by pushing in on the idler pulley arm. Make sure the new belt is placed flat along the exterior of the drum.
  6. Step 6 Replace the screws back into the dryer's front panel. Screw them in tightly so that the panel will not fall off or jiggle loose.
  7. Step 7 Reconnect the power source back to your dryer. Either plug it back in or flip the switch in the breaker box.
Posted on May 13, 2010
Beko double oven the fan has started to make a loud noise and sometimes cuts out had oven 18 months
by loud noise do you mean squeeling squaking .
then its the fan bearing just order another fan motor.
Jul 25, 2014 | Ovens
Squaking noise on turns
cv joint look and c if the boot is broke if so need cv axtso
Mar 19, 2012 | 2002 Subaru Forester
Candy cc217-80 condensor dryer manual - I need to replace the belt and not too sure how to get to it
hi iv just bought a second hand condenser dryer its the candy cc2 17 and it squakes and make a loud noise what can i do to fix it??
Sep 23, 2010 | Dryers
DGGX2 smarload gas dryer starting to make squaking noises and shake. Don't know what the problem is
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 20, 2010 | Fisher and Paykel DGGX2 Dryer
Massager squeaks
Zip off the cover and add some talcum powder to the inside cover where the roller make contact with the cover.
May 03, 2010 | Homedics SBM 300H Therapist Select Shiatsu...
Dyson upright vacuum cleaner makes horrendous noise
It might be a simple as changing the clutch belt and the drive belt and cleaning out the brush roll. You can get replacement belts here:
Dyson DC07 Belts
Dec 08, 2009 | Dyson DC07 All Floors Bagless Upright...
Amana NDE2330AY Electric Dryer Logo
216 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
