My washer keeps coming up with a code E20 and will not complete cycle. It usually goes all the way to the spin cycle and just continues to drain until it comes up to error E20. Any suggestion?
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
My Affinity washer gives E 36 and E68. E68 says test 14 just what is test 14.
My dryer has a code E68 the dryer is a frigidaire LEO6000ESO
Thank you for your inquiry, B.paddock!
From what you have described your Frigidaire washer is displaying an "E20" code and once the cycle is completed the clothes are still wet. Typically, an "E20" code stands for the water is not pumping out fast enough. You should check your drain hose to make sure they are not restricted or clogged. If your hose is fine it could be a possible issue with your main control board or drain pump. I would then suggest contacting a professional technician for proper disassembly of your washer and replacement of the electrical components. If you do not have a professional connection you can visit your manufacturer's website to locate a technician in your surrounding area. I hope this information is helpful. -Matt
control board on a affinity atf6000es..where is it located?
Error message 5f keeps coming up and machine stops - not sure on which cycle
