Dbx Driverack PA LCD problem
HI, The LCD display lights up, can have its backlighting adjusted, and the unit is functioning - sending editing parameters to the speaker system - but no data shows up on the lit display screen.
Any thoughts? Thanks a ton.
  • mringger Sep 25, 2008
    I have the same problem! It just happened the other day...
    Any help would be greatly appreciated!
I just read in another forum that the LCD display appearing black (but backlit) could be due to the ribbon connectors being loose behind the screen.
You would have to open the unit to check...
However, this would most likely void your warranty if your unit is still under one.
Hope this works...
Posted on Sep 25, 2008
Driverack pa plus sends this message WAITING FOR FLASH DOWNLOAD V. 0.109. i tried hard and soft reset but nothing happens, is there a solution?
The unit has been put into the mode to reload the operating system. You need to connect it up and load it with fresh download of the system. You can probably download the firmware from the manufacturer's site in their support section. There may be no other way to restore it. Be careful as any corruption during a flash download can be fatal requiring return to the manufacturer for reloading. Find the firmware for your unit here:
http://www.dbxpro.com/Software.php
Follow the directions for instalation TO THE LETTER !!! Read twice before doing !!!!
Jul 21, 2011 | DBX Professional Products DBX Driverack PA...
Good day..The common problem in a closed pa system setup is feedback.It limits the capacity of unit to give a higher intensity of volume..With this I just want to ask if DBX Driverack pa+ will work well...
The DBX driveracks work well with about any PA. The only PAs you might encounter a problem with would be one of the newer line array and digital processing PAs. Let your audio person get creative, the presets for multiple PAs are just a guide. If your sound person is confident and is qualified, let him/her experiment and/or rehearse - you'll be amazed at what that system is capable of.
Mar 10, 2011 | DBX Driverack-Pa Eq/Speaker Control System...
How set up my dbx driverack 480
Use the setup wizard on the on-screen display.
Sep 16, 2010 | DBX DriveRack 480 Processing Unit Home...
DBX PA+ no settings for Yorkville EF500P and LS801P
yeah that is because Harmon makes JBL speakers and Crown amps..for Yorkville Speakers use the VTC DLMS4080 Speaker processor, it blows the Drive PA away...
May 05, 2010 | DBX DriveRack 480 Processing Unit Home...
White screen on the dbx driverack pa? how to fix?
You can adjust the LCD contrast by pressing the Utility button and turning the dial one way or the other. Pressing the Utility button toggles back and forth between LCD contrast and Compressor/Limiter Threshold Meters, so since you can't see anything in the window you may have to press Utility twice, though I think LCD contrast is the first option.
Jan 17, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
When going through the driverack pa setup wizard, where is the "custom" speaker setting?
You should be able to spin the dial all the way to the end of the list of speakers and there you should see custom.
Jul 15, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
DBX DriveRack PA power failure
repair the transformers,,,using a digital voltmeter when both transfrormer are good the measure like 56 ohms, if one is good and the other is bad is gonna measure like 120 ohms , if both are damage it will measure nothing, all this with the switch in its on stage.
If you dont find anyone that can repair the transformers buy them.
Jan 28, 2008 | DBX DriveRack 480 Processing Unit Home...
894 people viewed this question
 Grubhead
Grubhead
