I agree this would be best to have a service technicians service this machine being if an attempt is made from first solution and doesn't solve the issue and a service technician does have to be called it may cost more.
make the priority fixing the water with an overdose of chlorine making sure to not use the pool for swimming while doing this, after the green goes, and you will know when you have put enough chlorine in when it clears up, then re adjust your pH level. after the level is correct, use the pool as normal .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Hello Devsi, hi, check your VGA cable connection for loose connections, try tighten it first to see if it solves the problem. the greenish thing is cause by a missing red signal, and the distortion is caused by a missing horizontal sync signal, also check out if there are bent pins on your monitor signal cable. just unplug the VGA cable and see if the pins are in order. if bent, carefully straighten it with a slim slotted screw driver.
