Question about Motorola Mobility MOTOROKR E6
To use my mobile as modem and do applications on my system
I have motrokrE6 which i want to connect it through usb to the system and i want to browse the net by activating gprs
how is it possible
  • 190 Answers
Http://www.howardforums.com/showthread.php?threadid=1136583
Posted on May 14, 2010
Unlock huawei E353Tu-6 mobem
HUAWEI E353 TU-6 and Huawei E353 are same modem...You can Unlock it using the Unlock Code...Visit the site Prounlocking.com/huawei-modem-unlocking-service/rs8wp10/ get the Unlocking service for your HUAWEI modem and unlock it from service provider lock.Follow the instructions below and unlock it step by step...
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response"OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Oct 12, 2012 | T-Mobile Huawei T-Mobile Webconnect USB...
Utstarcom um100c software for windows 7
for your download click htt
This device will work on win7, no problem. You'll need the install disc or the software.
UM100 win7 64bit
1.Double-click the quicklinkmobile.exe application from cricket. It will unpack a folder with the installation files in the same folder the quicklinkmobile.exe app is residing.
2.Go in that folder and click on start.exe, then click on install quick link mobile. Go through the normal setup as you normally would.
3.Once it finishes installing, connect your UM100 UTStarcom modem on a free USB Port. Don't open the Cricket Wireless application just yet.
4. Go to start menu, right click on Computer and select properties. Then click on device manager on the left. You will find the UM100 modem has an exclamation point on it.
5.Right click it and select update driver. Select "Browse mycomputer for driver" Option at the bottom. Click on Browse to select a driver from a location, then navigate to your root drive (usually C: and sometimes D then to Program Files (x86)/Cricket/Quick Link Mobile/System
6.Make sure you navigate to this cricket wireless installation folder. It should be in C:\Program Files (x86)\Cricket\QuickLink Mobile\System. Once you find it click ok. Make sure "Include subfolders" is selected under it. Click on "next" and now it will install the driver.
7. After it installs, it will create two more Unknown devices with exclamation points. Wait a couple of minutes for the system to finish up installing that one before you continue with this instructions.
8. Now repeat steps 5 and 6 above for each of the two unknown devices until there are no more devices with exclamation points in device manager.
9. Now open Up Cricket Wireless application on your desktop or start menu, and continue with the normal modem activation of the wizard that appears. That's it! It will now detect the modem and activate it. Allowing you to use it.
10. Go and find whoever said you couldn't use this modem on 64-bit systems and punch them in the face.
11. Call me so I can punch them in the face again.
12. Enjoy your newly installed UTStarcom UM100 cricket modem on your 64 bit system. Ask Cricket to update their website with this information. Punch them in the face too for the sake of completeness
Read more: http://www.cricketusers.com/cricket-mobile-broadband-devices/20339-utstarcom-um100c.html#ixzz22FHP7OMr
hope this helps
Jul 22, 2012 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
I want to connect my mobile to my pc for net browsing through mobile by usb cable. system replies that no modem was detected.whats the problem?
Tethering your cellphone to your PC is first dependent on whether your cellphone is GPRS enabled and that you have a a data plan (preferably unlimited internet) with the service provider. The next step would be to check the service providers website, which can provide an application and instructions on how to tether the phone with a USB cord or Bluetooth. You can usually find it by searching "tethering" on the companies support page.
If your company does not provide support for tethering, but does not restrict it (make sure to read your service agreement) you may still be able to do it. From the phone options/settings menu select "internet Access" choose the PC connection field and select USB. This may vary depending on your particular cellphone model, but the process should be similar.
Connect the cellphone to your PC. You may need to install the modem driver, which may have been provided with a CD included with the cellphone purchase or your OS may prompt to search for the needed driver. If you're using windows you will want to open the Network Connection wizard found in the Control Panel and create a dial-up connection. You can go to http://www.taniwha.org.uk/gprs.html and enter the listed user name in the account name and the listed password in the password field. The phone number will usually be #777, but if that doesn't work you may be able to find the number via googling something like "access number for [phone service]".
Good luck, I hope this helps.
Aug 20, 2011 | Computers & Internet
I want Samsung C322 driver to use mobile as USB modem to computer. How can I do it? Where I can get C322 drivers?
first u download Metro Duos C3322 pc connection manager .after u can
use chat c3222 as a modem and browse internet enjoy
Aug 19, 2011 | Samsung Computers & Internet
How do i use my mobile as a USB modem? that is, connect my laptop computer to the internet using my connected mobile
hello
to cennect to internet using mobile as a modem you need usb cable from your mobile to your computer and application of the mobile like nokia pc suite, once your mobile recognized by pc open the application (e.g. nokia pc suite) then select syncronized by select first the model of your mobile to be used as modem. then click syncronized and after syncronized select connect to internet.
thank you
Mar 07, 2011 | Computers & Internet
I want install tata photon+ in linex
hi...
many mobile phone companies don't provide drivers for linux.
But there is a software i would personally recommend to you. Actually its not a software, its a shell script.
Name of the software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
You can use this software for the following
  • connect to mobile devices by IR, bluetooth, USB Cable
  • Send and receive files between computer and device
  • Access Internet from Device by Dial Up Networking
  • Browse files on Mobile device
  • Mount the mobile device on a user specified mount point or communication port.
  • usually it mounts connected mobile device to /dev/rfcomm0. Through this port, you can communicate with the device .
  • Connect to USB Modem (Like Reliance DataConnect, TATA Photon, IDEA Netsetter etc.)
  • ability to connect to any locked/unlocked USB Internet Modems (Zero Devices)
fully automated connection setup. No manual input is needed except to specify connection name.
http://www.sakis3g.org/versions/latest/i386/sakis3g.gz
You can find more details and download Sakis3g from this address
http://www.linuxconfig.org/mobile-broadband-connection-and-sakis3g
hope this will help you to solve your issue.
Feb 17, 2011 | Red Hat Enterprise Linux ES 3 Standard...
I need usb driver in linux for my mobile samsung sgh x820
hi...
many mobile phone companies dont provide drivers for linux.
But there is a software i would personaly recommend to you. Actually its not a software, its a shell script.
Name of software is "Sakis3g". It can connect to mobile phones and other mobile devices which can be detected by linux kernel. You can use IR, Bluetooth, even USB cable to connect to your device.
  1. Send and receive files between computer and device
  2. Access Internet from Device by Dial Up Networking
  3. Browse files on Mobile device
  4. Mount the mobile device on a user specified mount point or communication port.
  1. ability to connect to any locked/unlocked USB internet Modems (Zero Devices)
  2. fully automated connection setup. No manual input is needed except to specify connection name.
Dec 12, 2010 | Samsung SGH-X820 Phone
I cant connect my HTC p3400i using my Homepc
Browse the Web on your mobile: Download settings from your Service Provider...
Browse the Web on your Desktop PC using your mobile as a modem - Activate blue tooth on your mobile & your PC (If no internal blue tooth port like most Laptops) you will have to purchase a separate Blue tooth dongle and follow the setup instructions....hopes this makes sense.
Jul 16, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Nokia N72 USB port
you need drivers for your nokia install on your PC. Check any CD if you got one or browse www.nokia.com
Aug 06, 2008 | Microsoft Windows 98 for PC
Not able to install net connect through my mobile
hi download LG KG195 PCSUIT and use your mobile to connect to internet ,etc
CLICK HERE TO DOWNLOAD
http://in.lgmobile.com/web/web.support.manualRF.laf
download the USB driver
modem driver
PC sync pc suite
Jun 11, 2008 | LG KU990 Viewty
Motorola Mobility MOTOROKR E6 Logo
75 people viewed this question
Top Motorola Mobility Computers & Internet Experts
AJMAL KHAN
Tom Chichester
Abby Carter
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
