Question about Garden
My tiller 917 299440 won't start. It has new gas,
My tiller model 917 299440 won't start. It has new gas, new oil, clean filter and new plug. Adjusting the choke doesn't help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Check to see if there is spark. if there is spark then spray some carb cleaner in the carb to see if it statrs if it does check fuel lines and gas filter if there is one
Posted on May 13, 2010
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
Tiller won't start. brand new
did you mix proper gas and oil. check or replace plug and check for spark
Apr 21, 2013 | Ardisam Inc Earthquake Mini Cultivator
What causes oil to come out of exhaust. was running fine 3 weeks ago.
ethanol gas for one thing. When it is left to set it breaks down the gasoline. You have a two cyc. engine (gas and oil mix) Clean the plug then take the unit and shake the unit to mix the gas back up. This may not work but its worth a try. Or drain the unit completely use non-ethanol gas make a new batch and replace plug.
Feb 22, 2013 | Troy-Bilt Pony Garden Tiller
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
Engine wont start. Changed plug; mixed new gas/oil combination. No start!
if you have a spark at the plug try cleaning the air filter, could be just dirty
Jan 07, 2011 | Mantis 2-Cycle Tiller
Troy Bilt Rear tine tiller model 643 Bronco, won't start,it ran out of gas, put in new gas and it started but wouldn't stay running. Put in new spark plugs, cleaned filters, changed out gas,still won't...
did it run out of gas when you added gas it could be that the fuel line has plugged up with something from the bottom of the tank take the fuel line off and try blowing threw it and take a air hose and blow out the carb and carb cleaner
Jun 05, 2010 | Troy-Bilt Pony Garden Tiller
I have a bolens rear tine tiller that will not run. The carborator has been completely cleaned, new gas, new spark plug, new oil, and new gaskets. It seems like it is not getting gas from the tank. Will...
is the fuel filter clogged? you may need to check the engine compression for bad valves or rings.if the compresion is off it wont get gas . check the fuel filter first though and keep me posted.
Apr 23, 2009 | Mtd Products Yard Machines 158CC Tiller
Tiller won't start
Remove the airfilter and take a look at it. If it is dirty or has a lot of oil in it, that would explain why you can't start the machine. If that is the case get a new filter and you will be up and running.
please mark this answer as a fixya. thanks
Mar 18, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
188 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
