Just opened up the camper to find inside soaked on inside of unit
Just opened up the camper to find inside soaked on bed that is under a/c unit. Romoved cover on inside and noticed bolts were loose so snugged them up. When I did that water started to drip inside of trailer. I have not removed the outside cover of unit yet. I have a constellation Comet with a Carrier A/C unit. Any ideas
    Guru:
  • 415 Answers
Check the condensate drain port for blockage and clear the blockage.
If the cover was on upside down, it is possible that it was impeding the air entering the coil.....this could have caused the coil to frost up....during your time to shut the unit off and inspect, the frost/ice started thawing and dripping into your trailer.
Here are the main items you want to address:
1. Ensure the drain is free and clear.
2. Ensure the air filter is clean and properly in place.
3. Ensure the evaporator coil is clean.
4. Ensure the covers are properly in place. ;-)
I hope you find this information to be very helpful to you moving forward. Let me know if you have any questions. Please don't forget to leave a rating for me. :-)
Posted on May 13, 2010
1995 terry camper electric slide out doesn't move can you move it manually?
Yes, all campers with slide outs have a way to manually crank the slide in/out in case of motor or electrical failure. The fun part is figuring out where exactly the place to insert the tool, if you have it. Larger slides with rails typically are brave to the main frame under the slide out whereas the smaller type (bed) would be under the bed and the false floor for protection.
May 04, 2017 | RVs
Roof leaking on 2003 breckenridge camper
Most roof ac units sit on a seal that fits around the opening outside, and on the inside there should be 4 long retaining bolts that that have or go thru some brackets, that squeeze the unit down. Kinda "sandwich's" the roof, if you will. I've simply tightened these 4 bolts carefully, and stopped the leak. Or the seal is damaged. And it also may be the drain. The opening will be under the plastic shroud. With the shroud removed you should be able to see a small opening near where its wet on the roof. I normally spray quickly with water at the opening. It normally clears easy. Condensate drain or weather seal.
Jun 27, 2015 | Heating & Cooling
My Chevy pickup factory antenna for my serious
Wilson electronics makes a cb looking GPS antenna you can mount the antenna to camper disconnect the coax with the camper and run an extension coax to the bed of truck for the dis connections.... then plug into your SIRIUS Radio to that extension coax..
Sep 04, 2014 | Radio Communications
How can i access the drive unit for the bedroom slide on my 2009 Forest River Flagstaff Classic Super Lite FKBSS?
If the bed is on the slide, more than likely the mechanism is under it. If not then it should be outside in the under belly.
I would check for voltage at the switch first.
Aug 03, 2014 | Forest River 2009 Flagstaff Classic 823
Where is the drain?
There are grooves on both sides of ac unit on a camper and it drains down the roof to a little gutter that travels the water towards end of camper and drains. Most of the time down the side of camper, but if these Grove are stopped up it will not allow it to drain and cause it to overflow inside camper. If filter is very stopped up or evaporator coil is stopped up, fan not running, low on refrigerant, or having the thermostat set way to low can cause it to freeze up and when this water thaws out it is too much for the drain to handle and also ice could be sticking being the drain pan melting causing it to go in your camper. I would check filter and those drain grooves first.
Sep 17, 2012 | Coleman Mach 15 Air Conditioner
I have a 2002 Dodge Dakota SLT, club cab, 4wd, 6.5 bed,automatic w/ overdrive, 4.7. If I have a 1200 lb. camper on the bed of my truck, how much can I safely tow
dakota is meant from manufacture to haul max. 5,000 lbs so you have a 1200 lbs camper that leaves you a capacity of tounge weight of 3800 lbs safley and anything over may cause severe damage to your vehicle,or others around you,be safe
Jul 05, 2011 | 2002 Dodge Dakota Club Cab
I have a 2000 Fleetwood Bounder 34T motorhome - the bedroom slide does not operate correctly. I want to see about adjusting the motor / slide mechanics but cannot find how to access it. I cannot fin an...
Check under the bed. May be some panels that need to come off to access from there. Check distance of bottom panel under bed, to floor. Likely under there. What adjustment is it that your trying to make? What's the initial problem your having? Is there any lower compartment space below bedroom? Sometimes they have an access panel under there as well.
Apr 10, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
I just bought a 1976 Chevy with an Open Road camper on it that goes over the cab. It seems that Open Road Campers Inc. does not exist anymore. I don't have a manual for it (the camper) and can't find...
Is it a slide in camper? and if so there should be jacks that go at the 4 corners above the truck box. you lift the camper up slightly and drive the truck out from under the camper. The jacks could have been removed and stored in the camper under a bench seet in the dinett.
Mar 22, 2010 | 1986 Volkswagen Wagon Camper
Help, Brand New A/C unit drippin inside camper
they do that its normal operation, you will get varying amount depending on your location and humidity. If it is not balanced or installed right it drips in the camper.
Aug 16, 2009 | Dometic Rooftop RV Air Conditioner
Auxiliary battery use
The extra battery is there because of the glow plugs and intake heater of the duramax. During cold weather both of these systems draw high amperage from the batteries. A single battery will function, but not as well as a pair.
Apr 08, 2009 | 2005 GMC Sierra 2500HD 4WD
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
