Question about Sony VPL CS5 Multimedia Projector
My Projector doesn't start VPL-CS5
Hi
When I would start my projector today, nothing happened. Have tried to use the connector on the projector, but neither the lights or fan started .
Can it be a Bulb problem?
Reg Stan
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
SOURCE: Sony VPL CS5 Multimedia Projector Problem
The Temp/fan light is on and is shutting down the projector what do I do
Posted on May 07, 2008
  • 5 Answers
SOURCE: Sony VPL-CX6 Projector turns itself off. No image projected.
does the "lamp/cover"-led light up? i had the same thing happening, the lamp either broke or is about to break and the projektor won't turn it on again to protect itself. if its very urgent, open the projector pull the lamp out and put it in again, it might work for 1 or 2 more times, but it is very likely to explode (usually not breaking the projector but for sure not good for it).
good luck!
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: DIRTY LAMP FOR VPL-CS5 SONY PROJECTOR (USED)
to clean the lamp: no chemicals, nothing abrasive. you can touch the outer glass (not with your fingers), but do not touch anythjing inside the bell. best thing to use is a microfiber cloth. your lamp is nearing or has passed 2000 hours of use. the projector is telling you to replace it before it blows (and sometimes shatters). after you replace it, reset the lamp timer (through the menu).
Posted on Dec 17, 2009
Testimonial: "I really appreciate your information, it was very helpful! Thank you and have a nice day..."
johnjvs
  • 29 Answers
SOURCE: my vpl cs5 projector is 5 years old. It has no
The problem I can confirm is either one of two faults in the main power supply section.It is either one of the double diodes in the TIP type casing which has gone short, or the other most common is the main oscillator IC in the primary of the power supply.Please check the double diode first as the main IC is about twenty pounds very expensive.Please also note change the three capacitors in the primary power supply section whilst you are at it.kind regards John Williams www.jvsvisual.com engineer to the stars.
Posted on Jan 23, 2010
Sony vpl cs5
Original lamp for cs5 USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 16, 2014 | Sony Lamp Module for Sony VPL-CS5/CX5...
Sony vpl cs5 projector will not turn on now power what so ever... Fuse on main power board is fine and power is getting to the main board at the back of the projector (the board which runs the bulb) the...
Have you tried the following:
Connect the power cord and turn the projector to standby mode.
Press the following keys on the remote commander in the following order for
less than five seconds each: RESET, <,>, ENTER.
Feb 26, 2011 | Sony VPL CS5 Multimedia Projector
How to reset lamp counter of sony grand wega tv
Try calling Sony:
US:1-800-222-7669
Canada:1-877-899-7669
I found a manual online but says nothing about resetting the timer so call them and they should be able to walk you thru it.
Feb 18, 2010 | Sony LMP-C150 Projector Lamp for VPL-CS5,...
Dec 17, 2009 | Sony VPL CS5 Multimedia Projector
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Feb 21, 2009 | Sony VPL CS5 Multimedia Projector
Lamp change
You have to go to the settings on the projector and reset the lamp timer.. Go to your on screen menu and go to settings.. Good Luck
Mar 05, 2008 | Sony VPL CS5 Multimedia Projector
It just wont turn on
Pls open the Lamp unit and check it if it is giving the power indication on the panel.
Viren
Nov 17, 2007 | Sony VPL CS5 Multimedia Projector
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPL CS5 Multimedia Projector Logo
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
