Question about Kenwood KDC-MP228 CD Player
Wired remote not working - Kenwood KDC-MP228 CD Player
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Is kenwood deck known for this? I had the same problem with my kenwood, The only right way to fix this is try to get a new harness and see if it was the wire that was the problem, if this don't fix this, take it or contact your local kenwood dealer.. But if you want to be slamming now, this is what you can do. Have a power wire (with a toggle switch would be best) hooked up to the remote wire input on the amp, BUT if you don't unplug it the amp will have constent power, meaning your amp will stay on all the time. I just do this when i try trouble shooting, when my amp won't kick on, just to see if it comes on. Thats how i found out my remote wire on my kenwood was bad. Hope this was helpfull
Posted on May 13, 2010
What is error code 76 on a Rheem tankless hot water heater that has propane connection?
Communication Fault with Remote Control. At a minimum check the following: 1. Check remote control wiring for loose or damaged connections. 2. Bypass remote control cable by connecting remote control directly to remote control terminals on PCB. Replace cable if found to be faulty. Yes Either the wiring or the remote control is at fault. To rule out the wiring, disconnect the remote control and use a short, good jumper wire and connect directly to the remote terminal on the PCB. If the unit works using the remote, then the wiring is at fault. If the unit does not work, then the remote is at fault. Did the unit go to main burner? No Replace the Printed Circuit Board Remove remote control wires from wiring terminal on the PCB. Plug unit in and open a hot water source.
Dec 16, 2016 | Rheem Water Heaters
Why is wired Tzumi not working with Motorola?
Molly-
I would contact Camera 360 and Tzumi Wired remote developer to find out what the requirements are for the wired remote to work.
Once we know the requirements we should be able to find out if your Droid X2 has the capability.to use the wired remote.
Mark
Motorola Support
May 31, 2015 | Motorola Mobility DROID X2 Android Phone...
My linear garage door opener will work now and than ? on remotes but works fine with hard wired remotes ?
how old are the batteries in the remotes. Hard wired remotes usually don't have a wire length limit.
Oct 01, 2014 | Linear Corporation Linear Garage Door...
I have a kenwood kdc 233 cd player in my car but the remote wire aint working because i tried hooking up an amp i pit a light power tester on the remote wire but dont work and i dont think the input plugs...
as far as the remote wire a keyed power wire from under dash can be used its the same thing.if the remote wire is working it wont turn on your amp so are you sure thats not why your rcas dont work or have u hooked power to the remote on the amp.
Nov 09, 2009 | Car Audio & Video
Amp not working to power sub woofer
remote wire/ fuse possible? have you checked?
traced all voltage?take and disconnect remote wire from amp and make short wire from remote to 12v if green light works then u may have bad remote wire or blown fuse.
Oct 05, 2009 | Kicker ZX10001 Car Audio Amplifier
Garage door opener remote won't work
look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
HOPE THIS HELPS
Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
My power locks dont work in side my van
check the wiring, connections, curciut braker, fuse link for the door opener on the side is broken, compair the wiring is the same setup on the working side and the non-working side.
something is different on one of the malfunctioning side, remote setting device has the correct wiring setup and the wiring diagram setting are defferent something is making the system to operate wrong or right. just be careful and teaduse, check out the remote switch and remote relay, fuse for relay, relay, find schamatics, look at the wiring remote wiring diagrams, and compair power connection for remote verses the non remote, see if any wires loose, dangling aound, loose, good luck
rod
Feb 16, 2009 | 1999 Chevrolet Venture
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Installed new hunter westminster and the lights work but no fan. and how do i get my hunter remote to work with fan?
begin by unscrewing one wire nut at a time to be sure that the wires are tightly twisted together before the wire nut is reinstlled. Once you have the fan working manually, the remote will also work.
Jan 07, 2009 | Hunter 27187 Remote Control
Auto amplifier installation
Does the new deck have a blue wire for remote and a blue/white wire also? The blue one is for a power antenna and shuts of when playing discs or axillary inputs. The blue/white is for power amplifiers and stays on when the deck is on. Also be sure the remote wire that goes to the amp is not pinched and grounded out to the frame of the car. Let me know, and be sure to leave feedback or I don't get paid.
Sep 30, 2007 | Car Audio & Video
Kenwood KDC-MP228 CD Player Logo
152 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
