Question about Whirlpool LER4634J Electric Dryer
Dryer was working, opened door to add something I forgot and would not come back on. Changed switch, checked breaker box, tested wires with meter.....nothing. Any suggestions?
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerdryer was working, opened door to add something I - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_nodryer was working, opened door to add something I - 2_bing.gif/a>
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 14, 2010
Does a 1987 gmcjimmy s-15 have a power window relay ot any relays at all cuz my power windows stoped working it runs a 30 amp circut breaker can the circut breaker go bad?
Anything can go bad, but to my knowledge circuit breakers seldom do. If you have a test light, pull the circuit breaker and probe both terminals for a power signal, with the key on. One terminal should show voltage with key on. If not, check the power distribution box for a blown maxi-fuse, or the wiring from that box to your fuse panel.
BTW, no, no relays are in the window circuit. So if the circuit breaker has power to it, put it back in and check for power on the driver's door master switch-one wire on the master should have voltage with key on. If no hot wire to the master switch, check inside the door openings for a broken wire. If you do have one hot wire there. check the power windows ground-the ground wire for the power windows originates at the master switch and goes back into the cabin to a nearby ground. Put one lead of the test light on the hot wire (key on), and probe the ground terminal at the master switch-if your ground is good, the test light will light up. If the ground is lost, no light. Check for a broken ground wire in the door opening, and/or find the ground and see if it is bad. If the master switch has a hot wire and a good ground wire, replace the master switch.
Apr 25, 2013 | 1987 GMC Jimmy
My kenmore dyer about 16 yrs old died on me in mid dry. It will not start now. I checked circut breaker in home was fine. I checked continuity in push to start switch,Hi limit thermostat, 250 degree therm,...
Hello there and thank you for choosing fixya
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block that it is attached too
Jul 31, 2011 | Roper REX4634KQ Electric Dryer
I moved. I changed the pigtail on the dryer. Now the dryer wont start but the light comes on when I open the door. I reset all the breakers.
Hello. Test the receptacle. If one of the hot leads isn't hot (120 volts), The light may come on, but the dryer may not operate. With breakers that throw two switches at one time (one to each bus bar, 120 volts each), it is possible that one side may be defective, or simply did not reset. If the receptacle is found to not have power on one of the hot leads, go back and reset the breaker several times. You can also test the output of the breaker with a volt meter, but extreme caution should be used if working behind the shield in a breaker box. You may have to go there anyway if the breaker is bad.
If all of this tests good, the next thing to check would be your wiring connections at the back of the dryer. Make sure that the outside leads of the pigtail are connected to the hot legs and the two inside leads are connected to the common and the ground lugs. If the receptacle tests out properly, you can also test the voltage at the dryer terminals. It could be as simple as a bad cord. It happens, rarely, but it does.
Best regards, --W/D--
Feb 23, 2011 | LG DLE3733 Electric Dryer
HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
Hello there and thanks for choosing fixya
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
dryer_door-switch.jpg Door Switch
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
dryer_start-switch.jpg Start Switch
A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
dryer_thermal-fuse.jpg Thermal Fuse
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
dryer_thermostat.jpg Thermostat
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
dryer_timer.jpg Timer Motor
Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly.
dryer_motor.jpg Motor
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
Jan 23, 2011 | Dryers
Will not start
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached
Jan 01, 2010 | Kenmore 63942 Dryer
My Kenmore electric dryer won't start
Hi, The most comon problem is the fuse. Here is how to test it:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jun 20, 2009 | Kenmore 63942 Dryer
Dryer will not start
Go to the breaker panel and make sure the neutral is making good contact. Especially check for corrosion. If it is good there, look for other connections between breaker panel and dryer. It seem to me you have a bad neutral somewhere.
Feb 24, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Dryer will not turn on
Door switch
Thermal fuse
Wiring
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Dec 15, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Admiral Capacity Plus Dryer won't start. No light when door open. Plugged in, Circuit Breaker Reset, socket live, (tested). Internal fuse or circuit breaker?
hi yes there is a thermal fuse in the dryer at the back on the air duct a small plastic piece with 2 small blue wires check that also door switch thanks the appliance doc
Sep 22, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
