Question about ASUS Eee 4G Notebook
Installing XP I have followed the user guide instructions for installing XP up through step 7, but at step 8, where it says " select Format the partition using the NTFS file system" I can't find that option. Where is it?
  • 59 Answers
What DO you see at step 8?
does it look like this?
if so, just select a drive and hit enter.
Posted on Mar 29, 2008
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Thanks..
Sep 06, 2013 | Westinghouse Electric LCM-22W2 Monitor
Tip
Installing Windows XP (10 Easy Steps)
1. Install the windows disk.<br />2. Check your bios settings to make sure you have boot from CD drive selected<br />3.If you have boot from CD drive select, you will get a display which says "Boot disk press any key" . If this displays press enter.<br />4.Select the otipon you which, there is normally 3.<br />5.follow the onscreen instructions.<br />6.once it as installed you will need to remove the disk<br />7.follow windows xp instructions (Username, password, network settings ect..)<br />8.Select the display resolution<br />9.Windows is now working<br />10. Install any required drivers and updates.
on May 07, 2011 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
How to format windows XP from CD
Here is The Step By Step Guide to Format or install win xp from a bootable CD
(Warning: Do it at your own risk, Back up all you data before formating the drive.)
Step1-Insert the windows XP cd in your cdrom and than go to the BIOS by hitting "DEL" or "F12? when your system in powering on. Go to Boot order and make sure cdrom is on the first place.
Save settings and restart your computer.
Once you have successfully booted from the CD, you will see the Windows XP "Welcome to Setup" screen. Press ENTER to begin the setup process.
Step 2- License Agreement
When it shows about License Agreement just press F8(function key) to accept the agreement.
Step 3: Previous Versions of Windows XP In this step setup will search for existing Windows installations. after search complete will see two option "R for repair or Esc to install fresh copy"
Note:screen will appear only if a Windows installation is already exists on your pc. If you're installing on a brand-new hard drive,you have to skip this option and see step 5.
krbshg_1.gif Step 4:To Continue installing fresh copy
Press ESC. You will be given a list of partitions available on your hard drive.
Step 5: Partitions If there are multiple partitions on your hard drive, or you have multiple hard drives in the computer, use the UP or DOWN arrow keys to choose your install partition. Please note that your system partition needs to be a primary partition (usually the first partition that shows up in the list), not a logical partition.
The partition should be at least 10 GB in size. Make sure that all the data you need from this partition is copied elsewhere, because it will be deleted.
Once you have selected the right partition selected, press ENTER. You will see the next "you already have a system installed" screen only if you already have Windows installed on this partition. If you are installing on a brand-new hard drive, skip to Step 7.
Step 6: Continue Installing On The Selected Drive Press C to continue. You will be given a list of install options
krbshg_5.gif Step 7: Format The Selected Partition Select the option to "Format the partition using the NTFS file system (quick) and press ENTER.You will receive a warning about formatting the drive unless the drive is brand-new.
krbshg_6.gif Step 8: Continue With The Format Press F to continue formatting selected partition. If you still haven't backed up, this is the last change to backup your important data, after this step you will not to able to go back and restore your data.
krbshg_7.gif Step 9: Copying Files After the format setup will automatically copy files and restart your computer. Go to BIOS and remove cdrom from first boot device. Start your computer.
krbshg_8.gif Step 10: Automatic Installation After RestartSetup will continue to install after the restart. it will ask you for the product key and user name etc. Fill the forms yourself.
Jul 10, 2011 | Computers & Internet
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
How to format pc please show me how
Before you do format your harddrive back up your drivers onto a flash pen or cd first there are free programs on the net to do this. For some reason installing xp to a system you can put money on it you wont have the network driver.
Your going to need an external cdrom as i dont think the ASUS 900 has one? What you need to do is boot from an operating system cd (eg. XP or Win7 or what ever your using) then follow the instructions on screen to guide you through formating and installing of a new operating system.
As i dont know what OS your installing i cant give a step by step guide but the on screen instructions are simple to follow.
Nov 14, 2010 | ASUS Eee PC 900 Notebook
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
How to format os in compaq cq40-616tu os is windows xp sp3
If you not a professional, don't worry about it.
Follow these steps;
  1. Insert the Windows XP CD in CD-ROM/ DVD-ROM etc.
  2. Boot from CD-ROM and press any key when it required.
  3. Now press enter
  4. Press F8 when it will be required.
  5. Now select the drive C for installaiton of OS XP.
  6. Now choose format option FORMAT with NTFS or FORMAT with FAT (its your own choice)
  7. Now press F
  8. After formatting the files will be installed to copy on the disk and now in the end follow the instructions to installing windows.
Good Luck
Jan 26, 2010 | Microsoft Windows XP Professional With...
Can I use the same installation disk that came with the printer when I installed it for windows xp for my nre windows 7
No.
Instead, access the manufacturer's web-site:
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Step 1: select "printers".
Step 2: select "Pixma iP series".
Step 3: select "Pixma IP90"
Click "Go".
Click "Drivers and Downloads".
Select "OS is Windows 7".
Download the appropriate "Guides" and "Manuals", and read them.
Download the appropriate device-driver.
Follow the instructions in the "Easy Setup Instructions" guide.
Nov 17, 2009 | Canon PIXMA iP90 InkJet Printer
I need to format the laptop
If you do not have the drivers for the devices that are installed on your laptop, then download from the IBM/Lenovo WEB site, make sure they are for your model laptop (eg. Video, audio, modem LAN etc.) before you format and reinstall Windows..
Follow these steps.
1. Boot up the laptop and press F12 function key to get a list of boot devices, select the CD drive.
2. Insert your Windows XP CD into the CD drive.
3. Press the space bar to start the bootup from CD
4. During the install process you delete the existing partition/s and create a new partition.
5. The next step is to format the partition - do a NTFS full format not a quick format
6. Follow the instructions to install windows.
7. After Windows completed the installation ,check on which device drivers didn't install and install these drivers.
Feb 05, 2009 | IBM ThinkPad R52 Notebook
ASUS Eee 4G Notebook Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
