Question about Jenn-Air 24 in. DW861 Built-in Dishwasher
Detergent powder tray door doesn't open during cycle.
I have a DW 860 UQW Jenn Air dishwasher. The detergent tray door doesn't open during the wash cycle. The left bin of the tray somehow releases the detergent but the right side is still full after full cycle is completed.
  • Jenn-Air Master
  • 43,501 Answers
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " Great tips, will get the handy husband on this asap........thanks
Posted on May 14, 2010
Dishwasher isn't cleaning
There can be a multitude of causes to a dishwasher not cleaning well. First, check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher and stacking bowls on top of bowls. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels, and tablets sold by Finish Corporation and Cascade work even better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Jul 06, 2012 | Kenmore PRO 24 in BuiltIn Dishwasher with...
I have a Kenmore builtin dishwasher model 17533200 , when I run it it doesnt seem to use the detergent even though the cleaner compartment opens.
Check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher or placing a large pan in front of the soap dispenser. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels , and tablets sold by Finish Corporation and Cascade work better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Nov 18, 2011 | Kenmore 24 in. 17533 Built-in Dishwasher
Soap dispenser door doesnt open during wash cycle
I have had this problem on a dishwasher IF I overfilled with powdered detergent. It would cake and the door would not open. Now I always leave a little space.
Mar 27, 2010 | Roper 24 in. RUD4000M Built-in Dishwasher
Cannot unlock door lock
Can't help on the lock release, but will say that OFTEN the detergent will not dump if it is filled too much. Leave a little space.
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Dishes not cleaned
When ever I hear of a dishwasher "suddenly" not cleaning properly, with spots on the glassware and soap not dissolving:
-If the spots are white patches, you can suspect the DW detergent powder. Go buy a name brand of detergent powder and I bet you will see a dramatic improvement. You may need to run a cycle or two with white vinegar added (up to two cups added after the DW starts, fills and begins to wash.)
-If the spots are a film / slime, you should suspect that the heating element. For the dW to be effective cleaning and rinsing clear,the DW needs to raise the water temp during the ~wash~ cycle (after the detergent dispenser has magically opened. After the heating element has been replaced, you will see an immediate improvement.
-If you had reported food debris sticking to dishes, (which you didn't), the first thing to do is clear the holes in the wash arms, then open the sump area , remove the filter assembly and inspect closely with a flashlight to locate blocking debris. (watch out for broken glass!) Inspect the impeller and make sure it is not damaged. If after assembly, the cleaning is still poor, it is time to replace the wash pump / motor assembly.
Good Luck! Ask more questions as needed!
Mar 30, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
163 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
