Question about Panasonic RR-US500
How to erase recordings on the Panasonic RR-US500
I need to know how to erase recordings on this thing, pushing the erase button and enter/play button isn't working. Thanks, Stephanie.
  • Anonymous Mar 31, 2014
    Unable to record/listen/change folders and it is fully charged
I called the Future Shop where I bought the recorder and the salesman looked at the manual online and saw that the Delete instructions do not tell you what you need to know.
To Erase or Delete recordings from this recorder, you have to select the track or file you want to erase, hit the Erase button, see that track number flashing THEN hold the Erase button down for a full second.
You can toggle until ALL comes up and then erase all your files at once if you wish.
You can also hit the Erase button first and then select the track you want recorded. The important thing to know is that you then have to see the number flashing THEN hold the Erase button down for a full second.
Posted on Mar 30, 2008
My PC can't recognize my Panasonic IC recorder RR-US500
Which operating system are you using? This recorder has known issues with windows vista and windows 7 as well as Mac OS.
If you're using one of the above windows operating systems, try right clicking on the installer (setup.exe) file, select "properties". When the properties windows opens, select the compatability tab, and choose windows XP SP3 from the drop down menu, as well as click the box next to "run this program as administrator". That should run the installer as though you are running windows XP, and it should work.
Jun 06, 2012 | Panasonic Audio Players & Recorders
I just plugged in the RR-US500 to my HP dv6 laptop and it won't sync. Can anyone help?
necesito descagar el sofware M66291 GP de RR-US500 para windows 7 en peru!!
Sep 07, 2011 | Panasonic RR-US500
Hello i am having problems using the panasonic RR US500 recorder on my mac
Welcome to Fixya. The problem that your experiencing is happening because the RR US500 is only compatible with Windows Operating System Platform. Unfortunately you wont be able to use this on your mac.
Thanks
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
How to recover erased file from panasonic digital recorder
Hi, there
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Best regards!
Dec 04, 2010 | Panasonic RR-US500
Voice Editing 1.0 premium Update for Vista
Try this
Uninstall the software.
Reinstall the software
After installing the software update from Panasonic, plug your recorder into the computer. Go into 'Control Panel' and select 'Hardware and Sound'. Then Select 'Device Manager' and select 'Universal Serial Bus controllers'. You should have a device for 'Panasonic IC Recorder', it might be flagged yellow, right click on it and select 'uninstall'. Unplug your recorder from the computer, replug your recorder into the computer, the Device Manager screen will refresh and you should have 'Panasonic IC Recorder' back in the list. Try the Voice software, you should have in the drive list 'IC recorder'. Transfer your files.
It worked for me,
Pierre
Jul 27, 2008 | Panasonic RR-US500
Panasonic Portable Cassette Recorder/Auto Stop
try toggling the Hold button on the back. My question is whether activating the Hold button is the only to turn this puppy off.
Rojelio
Jan 12, 2008 | Panasonic RR-US050 Digital Voice Recorder
Panasonic RR-US500
It worked for me,
Pierre
Oct 31, 2007 | Panasonic RR-US500
Panasonic RR-US500 Logo
358 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
