Question about Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro lawn mower choking on mulched clippings multiple times
I mulched last year and didn't have this problem. I have always cleaned with the hose after each mowing. This year I am getting clumps of mulched clippings that choke and stop the mower. Help Please
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
There is a product called mowease that you apply to the blade and mowing decked after a good cleaning. it helps keep the grass from adhereing to the deck
Posted on May 13, 2010
Testimonial: "I kept wondering if there wasn't something that I could put on it to make it slide off. Thanks for the info. Now I just have to find mowease. Thanks"
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 | Worx Garden
1yr old won't start this year
Dirty carb. Remove screw on bottom off carb exposing the carb float. Clean the float bowl. Ensure the float is working by pressing up on the float fuel flow stops, let it fall down, fuel flow. Observe the screw that you removed from the bowl, Look for to see if it has a whole thru it. Clean out the whole if it does. Bread wrapper wire with 1 in plastic cleaned off wire works good. Observe center fuel port, use wire to clean out port going to bottom of carb. Remove pin that holds float and meter needle, use wire to clean out port. Reassemble. Ensure free movement of float. Float up no fuel flow. Float down fuel flow. Use carb cleaner to clean carb inside. Ensure choke opens/closes properly. Always use Stabile in gas.
Jun 11, 2013 | Toro Power Lawn Mower
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro GTS 6.0 hp idles up and down
Excess air or not enough air. Replace air filter. Spray outside of carb to clean & ensure choke movement is smooth. Water in gas may cause this also. Flush out tank, refill with fresh gas, always use Stabile.
Jul 31, 2012 | Toro Power Lawn Mower
Toro choke doesn't work
try cleaning out the carburator.
May 23, 2017 | Toro Lawn Mower With Toro Power Tools
My Toro Model 20070 that until now has always started on the first pull, won't start at all now. It started fine last week. It's getting spark (a little more yellow than blue). I replaced the plug,...
Hold the butterfly valve (behind air filter) open with a screwdriver, while somebody else tries to start it. Toro has had problems with atuomatic chokes. If it fires right up, thats the problem! If so, just wire it open, or contact Toro for a repair kit. Try using starting fluid, not carb cleaner, and spray directly into the head through the spark plug port. If you didn't do it already, blow out all the ports in the carb with compressed air, or carb cleaner. Also, be sure the safety lever is engaging correctly (top bar on handle) at the engine. Lawn mowers are pretty simple, so the problem is most likely simple too.
Sep 24, 2011 | Toro Personal Pace CARB Walk Power Mower
I have a Toro 20462 power mower -- about 15 years old, but until just today still running great! The spark plug is good, the gas is good, the oil is good the air filter is good. After priming, it starts...
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
Sep 11, 2011 | Toro Power Lawn Mower
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Toro Co M/R Blwr/Trmmr Rear Bag Kit Logo
279 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
