I need help! I got the FL error message. I tried to use the trick of pushing the set delay and then end of cycle buttons and then putting the jeans cycle on. It did everything except drain. How do I check if there is a clog in a filter somewhere and how do I access this area?
HI.I HAVE THE SAME PROBLEM BUT I JUST CANCELED THE LOAD.ALSO I'VE HAVE OTHER CODES SUCH AS LD AND OL I LOST MY MANUAL. SO I DON'T KNOW WHAT THEY MEAN.
AnonymousJul 21, 2008
I have the same problem as the fellow ****** that purchased a Kenmore Elite. Very disappointing. This is the second problem in 5 months. I feel like having the trash guys haul it away. I will try to fix it once more. Does anyone know how to clean the water pump first of all. Any help would be greatly appreciated. Thanks, TorrieI have the same problem as the fellow ****** that purchased a Kenmore Elite. Very disappointing. This is the second problem in 5 months. I feel like having the trash guys haul it away. I will try to fix it once more. Does anyone know how to clean the water pump first of all. Any help would be greatly appreciated. Thanks, Torrie
You can't post conmments that contain an email address.
I continued to push the set delay and end of cycle buttons, twice. Then I pushed the jeans cycle button and let it run its course. After doing that twice, it drained the drum and I tried to start a new cycle for washing, which worked. Yea!
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes * If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Your Maytag
Neptune washing machine displays error codes, also called "help codes,"
to identify specific problems with your washer. Once you close your
Maytag Neptune's door, the machine locks the door, goes through the
selected wash cycles and unlocks the door when the laundry is finished.
Do
FL
Sd
PF
Nd
LO
Lr
residential washer
displays error codes. Though designed to indicate the nature of the
error, to anyone without a copy of a washer manual handy, the codes
might as well be Martian cryptography. Luckily, the Manage My Life
website has partnered with Kenmore and made manuals for each make and
model of Kenmore washer available online. The error codes are
differentiated between top and front-loading machines.
FH Error Code
When a front-loading Kenmore residential washer displays the "FH"
error code, the machine is experiencing a water-inlet problem. A
water-inlet problem is the result of the washer receiving too little
water to operate. The Kenmore owner's manual suggests five home remedies
for this problem: Check that the water faucets
connected to the washer are turned on; that the inlet screens in the
washer's connection hose are not clogged; that the hose is not kinked;
and that the hose is not frozen. If none of these problems are present,
turn off the washer, unplug it, plug it back in, and restart the
machine.
FL Error Code
The "FL" error code on a top-loading Kenmore residential washer
indicates that the machine has over filled. When a residential Kenmore
washer is overfull, it will beep every 10 seconds. The pump will cycle
on and off every 30 seconds in an attempt to rectify the problem. To
stop the pump or restart the machine, either disengage and then
re-engage the power source to the washer, or push the overfill reset
switch. If water continues to enter the machines after the "FL" error
has appeared, shut off the inlet flow faucet or the machine will overflow.
F02 Error Code
The "F02" error code on a front-loading Kenmore residential
washer indicates that the machine is experiencing a drainage problem.
Home-remedy solutions for this error code, as suggested by the Kenmore
manual, are similar to those for the "FH" error code: Insure that the
drainage hose is not kinked, frozen, or clogged. If none of these
problems are present, check that the hose is less than 96 inches, or 8
feet, above the floor. A hose more than eight feel from the floor will
not drain properly
This means that your Washer has somehow Over Filled with water and will "FL"ood if it does not drain the excess water:
It should also be beeping every 10 seconds and the pump should start to empty some water to rectify the issue. Restart the machine machine as required or push the overfill reset switch. To avoid flooding, you might need to temporarily shut the water supply if water continues to flow in the machine while the "FL" code is displayed. Hope it helps let me know how you go.
Hi, The most common cause of an OE error code on a modern LG dishwasher is: 1. Blocked drain hose 2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3. Failing drain motor. else you need to REPLACE THE PCB POWER CONTROL BOARD Good Luck!!!
You said, The pipe in the back is not clogged, it is wide open. When we removed
the cover for the pump in the front and open the valve, the water
obviously drains out. However, when you put it back together and try to
run it, it will go through a cycle and when it gets near the end of the
cycle that when the message appears drainage blocked and won't drain.
The electronic type washers , can be unplugged and after 5 minutes restarted and the system is then rebooted. This resets the system and clears the codes !
If the drain is not blocked then you have a faulty sensor or a bad pump
