Question about Abit NF-M2S Motherboard
Abit nfm2s mother brd failed to start up from bio, i think it maybe a hardware problem , but am not sure , ...i installed a new ddr2 800 memory but after fitting the item , the mother brd will not start up at all .
  • 728 Answers
You a need a pair of identical memory modules must be placed in matching DIMM slots in order to to make it work. They need to be same mfg, everything.
Thanks Mark
Posted on May 14, 2010
I have changed the motherboard from Intel to Gigabyte(GA-G32M ES2L) since then the problem of my pc freezing while playing games started. My configuration is Processor:Pentium D...
1) Make sure that your Power Source is giving enough energy to the new Mother Board and make sure it's compatible.
2) Make sure that the new Mother Board is compatible with all of your current hardware, you can check this in the webpage from the Mother Board Company.
3) Check the voltage requirements for the Mother Board, check the BUS speed of the Mother Board and compatibility with the transfer speed of each of your current hardware.
4) It's never recommended yo change only a Mother Board since usually there's going to be problems with the rest of the hardware if it wasn't changed, if the problem persists, you'll have to buy new hardware that is compatible with your new Mother Board.
5) If you know how a BIOS works and how to configure one, you could also check the configuration in the BIOS, not sure it will work but it's worth a try if you know what you're doing.
May 27, 2011 | Computers & Internet
I had 2 x 512mb memory installed with no problems. I recently installed 2 x 1Gb but the bios does not recognise it. The pc always hangs on boot up just before loading windows. The pc will work with the 2 x...
Hello gphillips397!
Abit has released an updated BIOS for the IC7-MAX3 motherboard which fixes quite a few issues with your motherboard including one that can cause the system to hang with certain memory modules. The updated BIOS is HERE and instructions for the upgrade are in Appendix G of the User Manual or a general guide is HERE
Nov 22, 2010 | Abit IC7-MAX3 Motherboard
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Working SG-72 MOBOs failing 1 by 1, no POST after BSOD, just fans
test the cpus in other machines. if your not getting any boot or beeps, then it is the bios or cpu.
Jun 30, 2009 | Abit SG-72 Motherboard
Abit AN7 motherboard does not boot - POST code AF
i think thats memory so try removing your ram and re installing it. maby its not pushed in all the way.
May 09, 2009 | Abit AN7 Motherboard
Abit AW8 LGA775 Maximum memory
Hi there
Sounds like the bios will need updating as the board will support 8BG ram.
Put your old memory back in the machine, boot into windows, go to the motherboards manufacturers website and download the latest bios update and install it and reboot.
make sure you read the info on how to install the bios update.
I must also warn you that if you are using a 32bit operating system it will only recognize 2.9BG of memory, there is nothing you can do about this apart from install a 64bit operating system if the board supports 64bit processors.
Good luck and thanks for using Fixya!!!
Feb 11, 2009 | Abit AW8-MAX Motherboard
WON'T START
It might not start because you might have a shortcircut Warning !! your computer hardware can damage or a fire can start replace mother board or new hardware you installed
Jan 17, 2009 | Abit VI7 800MHz FSB VIA PT800 Chipset DDR...
Problem w/ Pcchips A13G+
PC-Chips infamous for memory controller issues.
In the BIOS, set the memory speed to the highest CAS and lowest speed. Make sure FSB and memory timing are asynchronous so you can slow the memory. Turn off interleave, etc...
Is your memory mismatched? Use one stick, and pick the best one.
Try a different one.
Almost guarantee it is a memory issue of some sort.
May 28, 2008 | Abit SG-80 Motherboard
No Booting to BIOS, Monitor just stays on Save
If there are no beeps at all on boot up it's a memory timing problem, Go into bios in standard bios settings menu and disable 'Halt On All Errors' if it isnt already, this may show up the problem in the initial power on self test.
Oct 26, 2006 | Abit SG-80 Motherboard
Abit NF-M2S Motherboard Logo
136 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
