Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
My panel doesn"t respond. I have a open sensor. I unable to operate the main panel to service the equipment. Doc
  • 22 Answers
Splice the wires and either seperate them or connect them this will make the unit think there is a operating sensor if that fixes the probelm replace the sensor. sensors are a common problem. plus there are a few different styles of sensors and alot of pool companies are not aware of it. you may want to call jandy they usually are pretty helpful on the phone 800 227 1442 is the number i think
Posted on May 14, 2010
Brother HL2130 press print and i want to stop the printing how to i pause or cancel printing do i just open the lid or can't be cancelled i tried to search via settings but unable to locate thankyou
most likely it has gone into the printer's memory.
Turn off printer at power point.
CHECK COMPUTER FOR PRINTER QUEUE
Also check computer for printers icon on right bottom of screen and click on it to open the printer queue.
Then cancel print job if in Windows operating system's printer pool.
Turn printer back on at power point
If you can't find the printer queue go to printer settings in the control panel of the p.c and find the printer queue.
If this is not possible for you to find.
Go to services (in control panel) if windows operating system and find the print spooler service and restart the service .
May 25, 2017 | Brother Office Equipment & Supplies
How do i fix samsung
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Apr 16, 2015 | Samsung Televison & Video
Unable to start dishwasher
If you are able to select the correct program and the panels swithes are responding but the program does not start then it is likely the sensors inside the dishdrawer are faulty. Try to turn the mains power off and back on and see if any difference. Otherwise most likely the sensor that checks the drawer is shut or not may be faulty and telling controller that drawer is not shut. Provide your actual model number if you want me to look into the type of part and location otherwise call Fisher and Paykel service technician.
Jan 29, 2014 | Fisher and Paykel Dishwashers
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Vcr sensor not responding to remote
Hello
If you are sure that the remote control works well, and VCR does not respond to it [you haven't here given any details about uour VCR; its Brand name, Model number etc:-], the remote sensor of your VCR is faulty. You can replace it, if you have an idea and knoledge in electronics. You have to disassemble the front panel of the VCR, to locate this device. It will come just behind the infrared window, will look somewhat bronish black in colour, a three terminal component.
gopakumarg43_89.jpggopakumarg43_90.jpg I hereby includes the picture of a typical infrared remote sensor, and its typical circuit dagram, to know you the pin numbers. Just try, if you are familier with electronic equipment service. If you are not skilled to do this work, get this set repaired by any experinced service technican. OK.
Oct 13, 2011 | RCA Televison & Video
What is code 14 on 03 zx636
Hi, here you go:
Service Code Problems
11 Main throttle sensor malfunction, wiring open or short
12 Inlet air pressure sensor malfunction, wiring open or short
13 Inlet air temperature sensor malfunction, wiring open or short
14 Water temperature sensor malfunction, wiring open or short
15 Atmospheric pressure sensor malfunction, wiring open or short
21 Crankshaft sensor malfunction, wiring open or short
23 Camshaft position sensor malfunction, wiring open or short
24 Speed sensor malfunction, wiring open or short
25 Gear position switch malfunction, wiring open or short
31 Vehicle-down sensor malfunction, wiring open or short
32 Subthrottle sensor malfunction, wiring open or short
33 Oxygen sensor #1 inactivation, wiring open or short (Equipped Models)
34 Exhaust butterfly valve actuator sensor malfunction, wiring open or short
35 Immobilizer amplifier malfunction
36 Blank Key detection
39 ECU communication error
51 Stick coil #1 malfunction, wiring open or short
52 Stick coil #2 malfunction, wiring open or short
53 Stick coil #3 malfunction, wiring open or short
54 Stick coil #4 malfunction, wiring open or short
56 Radiator fan relay malfunction, wiring open or short
62 Subthrottle valve actuator malfunction, wiring open or short
63 Exhaust butterfly valve actuator malfunction, wiring open or short
64 Air switching valve malfunction, wiring open or short
67 Oxygen sensor heater malfunction, wiring open or short (Equipped Models)
83 Oxygen Sensor #2 inactivation, wiring open or shout (Equipped Models)
94 Oxygen sensor #1 malfunction, wiring open or short (Equipped Models)
95 Oxygen sensor #2 malfunction, wiring open or short (Equipped Models)
Feb 01, 2011 | kawasaki ZX-6R Motorcycles
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
All words file are automatically open in powerpoint or unable to read
You need to make sure that the file type is set to open as a *.doc (Office 97 - 2003) or *.docx (Office 2007) Open up your 'My Documents' folder and then go to 'Tools' then 'Folder Options', then click on the 'File Type' tab. Scroll down until you see the file extentions for Word ( DOC or DOCX). When you click on them, you will be able to change what they open with.
Jul 03, 2009 | Microsoft Windows XP Professional
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
155 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
