Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Ol cabrio checked between tubs nothing not too big of load what next?
  • Whirlpool Master
  • 8,220 Answers
CABRIO REPAIR MANUAL
I think you may need to change the main control, but you better cover all bases first. Let me know.
Posted on May 13, 2010
What is code oL
Ol is rarely actually over loaded. Check the tub by pulling up on it. You should get a slight movement .The tub floats .if if doesn't the shaft and tub will need to be cleaned with sand paper. Also check for obstruction under the tub. Turn the tub by hand it should turn freely. Good luck.
Apr 26, 2014 | Whirlpool Cabrio WTW6600SBK
2007 Cabrio does not agitate, flashes oL code even when empty
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub.
Oct 14, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I keep getting the over load display after a few minutes even on the clean machine setting. i have taken clothes out but does not help. on the clean machine setting there arent any clothes in it but after...
I dotn have soe USA/Canada numer, but could answer and comment that your "OL" codes, with the tub empty, indicates, that there's a problem in the drive/ tub system or the fill level.
Two choice there, first is that your hub mechanism is sticking. This model floats the basket, and although it does not say so, I am guessing that too heavy a load stops this process. In your case the floating mechanism may be sticking, so the machine thinks it is too heavy a load.
The second possibility is a bad machine control board. In the next link culd find the Repair2000/Library/CABRIOHEWASHER as reference guide to solve it.
Hope helps (remember to rate and comment this answer)..
Jul 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio top loading washing machine stops with an error OL . nothing wrong with the loading, this is only a small whash. Where is located this sensor for overload?
The sensing is done by measuring the motor amp draw. If the motor amp draw is high that is an indication of a heavy loaded washer which could cause the motor to overheat OR too much soap being used, OR the wrong soap being used, OR something between tubs. If you is getting an OL and the clothes is not the problem then you may have an item lodged between the tubs. You must remove the inner tub and get that thang outta there. Cabrio service manual
Rate it or hate it!
Jun 30, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The oL warning comes on, just after the machine fills with water then it clicks through the cycles the water drains and the oL signal comes on. This even happenens when the clean cycle is operating.
oL Overloaded.
"oL" flashes when you got too dang many clothes in there. 18 pounds dry weight per load is what I go by. If the load is fine you could have an item of clothing in between tubs not allowing basket to engage.
Service Manual and codes HERE
Jun 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
We have a newer Whirlpool Cabrio washer and no matter how many clothes we put into it we always get a ol error.
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is oL code?
ol code is for over load. Too many clothes. Sometimes you will get this code with nothing in the tub and the water keeps filling then goes to drain. if this is why your asking then pull the back off the washer and pull the clear tube off the tub. Blow in the tube and then the washer will take off and start operating correctly, Well till you stop blowing. This is a pressure problem and air is leaking right there at the tub and tube. I suggest a little plumbers dope and put the hose back on. if machine does not return to normal then you got a little dope in the air way. Pull the tube and replace again. Wa La!
Apr 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
218 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
