Question about Dell OptiPlex 210L N (210LNDCELMIN) PC Desktop
My new hard drive seems to be working too hard and becomes non responsive, the fan also engages constantly. Lots of clicks and whirring noises. This is the same problem I had with the hard drive that came with the Dell 210 when I purchased it, which is why I replaced it thinking the issue would be resolved. Are there any known issues with the Dell 210L and it causing hard drives to **** out? HELP! any help at all would be greatly appreciated. Thanks!
  • 721 Answers
Well I hope you didn't replace it with an oem drive,because they ****. Go Western Digital & steer clear of Maxtor/Seagate. However, check some of this first. Go into bios after running for a while & check the cpu temp & board temps out. Anything running at or above 165 farenheit(65 celcius) is in or having a major overheating issue. In that case, a thourough cleaning is needed & a fresh dose of cpu thermal paste put on. While it's open be sure to check that all the fans are working. Some of those optiplex's had 2 cpus so be sure to apply new thermal paste to both,remember to wipe off the old stuff first. If the steps above don't help with the existing drive, download a program called "spin rite" & run that after making a complete image of your drive using Acronis or something similar for free off www.download.com . While you're at that site, grab Advanced System Care Free edition & run that as well. That's an easy one click program to use & fixes alot of wierd ****. Make sure you go into the diagnose system section,run that also then under utilities run the disk cleanup,internet optimizer,follow the instructions for getting the defrag program & select smart ram (set that so it starts with windows,same with the defragger). If all that doesn't work, replace the hdd with a Western Digital of similar size & if you used Acronis you can simply mount the image onto the new drive & you're done. All your apps, settings & programs are the same! It's like taking someone's brain out,putting it in a pickle jar & putting it back in again with them being none the wiser,lol.
Posted on May 15, 2010
Hitachi touro not responding
Hi can you hear any spinning whirring noise?
This could be a cable fault or the drive itself could be faulty.
You can download Hiren Software on USB to test the drive with the software
Sep 25, 2016 | Hitachi Touro Mobile Pro 500 GB USB 30...
Inkjet printer EPSON L 200 not booting up most times.Makes lots of Whirring noises, Scanner does not seem to initiate. After a lot of whirring and clicking all three lights come on. That's it.
Scanners tend to initiate simply by warming up their lamps and pushing the carriage back to its rest position
Whirring noises generally indicate either the ink pumps or the drive belts are faulty... which here might well mean the scanner drive belt is failing to return the scan heads to the correct position.
That would tend to indicate the belt or the drive motor have slipping teeth or there is a blockage, perhaps from bits of torn paper...
Aug 02, 2016 | Epson L200 All-in-One Inkjet Printer 27...
Loud constant noise (metal on metal clicking / whirring / grinding) during spin cycle
renault laguna 2006 diesel. unlock code for radio... modell renrdw100-10 .
n874 security...
pls..
thanks
Nov 22, 2013 | Whirlpool Washing Machines
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
Seems to be a noisy fan on mb4210 combo
Could very well be the fan. The motors can cause interference. There may be a solution to get rid of the noise. Some copper shielding tape may help. You could rule out it being a microphonic preamp tube by turning the amp on as normal and tapping the tubes with something non-conductive. If you hear the tapping noise coming thru the speakers while doing this to a particular tube, replace it. With power tubes, the tops of them turn white on the top when they become microphonic, along with plenty background noise.
Apr 18, 2009 | Marshall Music
My pc is making clicking and whiring noises
It sounds like you have a hard disk drive that's going bad. Take it to a computer expert and have them check it. The "clicks and whirs" might also be a cooling fan going bad.
Mar 28, 2009 | Computers & Internet
When engine fan engages makes loud squealing noise
Either tighten the fan/drive belt or replace it .. it is loose ...
Mar 22, 2009 | 2000 Mazda MPV
Unrecognized Drive, Unusable Files
Hi, did you try to upgrade your firmware ? You can try that, the firmware update also will reduce the fan noise, go here: http://support.wdc.com/product/download.asp?groupid=104&lang=en
Mar 12, 2009 | Western Digital My Book Pro Edition II...
Louder whirring noise when turning on computer
trumpjd,
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
randy320sgi
Jan 09, 2009 | E-Machines eMachines Desktop PC
Dell OptiPlex 210L N (210LNDCELMIN) PC Desktop Logo
74 people viewed this question
Alun Cox
