Question about Microsoft Picture It! Publishing Platinum 2002 for PC
Seems to load,but stop working window appears
  • 140 Answers
Its cause your computer doesnt have enough memory or or your computer doesnt meet the requirements
Posted on May 13, 2010
Cannot access network resource error when trying to load from cd
Just Simple.. You can try System Restore in Vista.. Cause in Vista can't not read automatic like vista. if your dont have Nero Disk try restore in good Condition before Software Crash..
Oct 26, 2009 | Computers & Internet
What replaces MGI Photosuite for Windows 7?
I had no luck with Photosuite 4 on Windows 7, even with backwards compatibility, vista or XP, but Photosuite 8.06 loaded up and appears to work okay, it is older but does seem to work on windows 7.
Oct 24, 2009 | Computers & Internet
Logitech webcam that doesn't want to work with skype now
I experienced the same symptom (Skype would load with WinXP but NOT recoginize my HP Elite webcam and its ArcSoft drivers). I noticed that I could 'cure' the problem by manually stopping Skype after WinXP loaded (right click on the Skype task and Quit). Then, when Skype has stopped running and Windows is still up, manually restart Skype.
It appeared that the problem was one of task startup order. My system runs McAfee's Secuity Suite and that takes a FULL 2.5 minutes to activate after the initial Windows desktop appears.
So, for grins, I searched for a freeware startup manager (used WinPatrol) and installed it. I assigned the Skype startup task to the delayed column and set the delay to 2.5 minutes so Skype wouldn't try to load before the McAfee firewall was up and running. That cured the problem of Skype starting without seeing a webcam!
I played with the delay and found even WinPatrol's minimum delay (10-30 seconds) also provided relief...
Aug 11, 2009 | Computers & Internet
Computer may or may not start up. When it does, it may or may ..
Go with a known good working hard drive, its the easiest thing to replace and instead of reimaging it, install windows from scratch and then load the drivers for whatever it doesnt find and then see how it runs, if the lockups stop happeneing then load the apps that you want and everything should be okay.
Jun 26, 2009 | HP Computers & Internet
Rear window wiper has stopped working
First, i would Check the cables for damage and splits where it goes through the rubber hose (offside) to your boot, seems to be a common problem with these cars, happen to my rear wiper and a friends electric windows electric windows cables had cut right through from openning and shutting boot !
Apr 25, 2009 | 1997 Volkswagen GTI
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
My computer is trying to configure and load windows photo gallery but it keeps saying I do not have the CD Rom I do not want to load this program I cannot seem to cance it and when I go into remove...
  • Click Start .
  • In the Start Search field, type msconfig, and press Enter.
  • The System Configuration window opens.
  • In the General tab view, select Selective Startup, and remove the checkmark next to Load startup items.
  • Click on Startup TAB
  • Under Startup TAB uncheck all of the Items except Following:-
  • For Windows Vista
HD Audio Control Panel.
HP KBD EXE.
Hp digital imagine - hp all-in-one series.
HPRun.
Hpsysdrv.
HP Total Care Advisor.
Microsoft Windows Operating System.
NVIDIA products.
Symantec Technologies products.
Windows Defender.
  • For Windows XP, do not disable the following startup items:-
Alcxmntr
Atiptaxx
ati2mdxx
Backupnotify
Ccapp
Ccregvfy
HPBootOp
Hpsysdrv
Kbd
LTMSG
NvCpl
ps2
Recguard
VTTimer
  • Click the Services tab, select Hide all Microsoft services, and click the Disable all button.
  • Restart the computer for the changes to take effect.
  • After the computer restarts, a message appears confirming some startup programs have been blocked from opening.
Jul 04, 2008 | Computers & Internet
Toshiba Satellite M35x-S1142 Turn off problem
Was something new installed. It's failing during the driver load. You can quick fix it, maybe, by booting and pressing the F8 key, then selecting Last Good Configuration (words of that effect). If that does not work, boot with F8 and trace each driver as it loads. The one it stops on is the one you want to deal with. Boot in Safe Mode again and try to fix the problem. Do you have anything showing up under the Question Mark in device drivers? You may need to deal with the problem on that level also. Cheers.
Apr 08, 2008 | Computers & Internet
Microsoft Picture It! Publishing Platinum 2002 for PC Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
