Question about Mag Innovision LT776s 17" LCD Monitor
MONITOR SHUT DOWN COMPLETELY - Mag Innovision LT776s 17" LCD Monitor
  • 180 Answers
Your LCD main board defect.
Open to see for capacitor that has pop up.
Posted on Apr 24, 2008
Still image is on the screen will not shut off have pressed the reset and nothing happens
unplug monitor let batterie run down completely plug back in and it should work fine.
Sep 14, 2011 | First Alert D545B Digital Wireless Baby...
My HP w2228h monitor randomly decides to go black and go to sleep. I cannot wake it up. The only way around this is to hold the on/off button down and completely shut down the cpu but I don't like doing...
You will need to update your video/graphics driver for your computer/laptop. This will fix the communication between your computer and the monitor.
Mar 09, 2011 | HP w2228h Wide LCD Monitor
Monitor blank after bios update
Try shutting down completely. Some BIOS updates kill the on-board video until power is cut off completely.
If that fails, hope you made a back up of your BIOS before flashing it. You could always order a replacement from the manufacturer as well.
Mar 17, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
How do i get out of hibernate mode and get into standby
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Dec 23, 2008 | LaCie Electron III 22" CRT Monitor
Hp ze2000 shuts down
Without more information I cannot be sure, but I would say that it could possibly be set to use an external monitor. There is a FN key command to switch between your LCD Screen and an external screen. Try that. If you have an external monitor that you can plug into the VGA connection, that should tell you for sure. Good luck.
Nov 12, 2008 | HP Pavilion ze2000 Notebook
Computer will not shut down completely
Please install a fresh copy of Windows xp or vista whatever. And install the proper and compatible drivers that should suit your motherboard. Don't install the drivers which does not support your motherboard or Operating system. Thank you...
Sep 10, 2008 | Computers & Internet
Will not close down
These monitors go into a standby just incase you are only restarting the PC.
To turn it off properly, hit the power button on the monitor before Windows has completely turned the computer off.
IE: tell Windows to shutdown, when you see the blue screen telling you Windows is shutting down, turn it off then.
Hope that helps
Oct 20, 2007 | Acer AL1715 17" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
32 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
