Question about Dometic Rooftop RV Air Conditioner
A/C ON ROOF TURN ON, BLOWS WARM AIR THEN CUTS OFF. HELP PLEASE.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Sounds like it is low on freon. it will cut out to prevent damage to the compressor
Posted on May 13, 2010
Warm aire on one side cold air on the other
Does it have passenger side controls
Feb 25, 2014 | Cars & Trucks
Air conditiner cools on right side but not on left side
It can be issue with blend door actuator or vacuum leak or loose vacuum hose connection.
I suggest you few help links.Click the link below and follow the troubleshooting.
A/C Blows Warm? http://whoisbyme.blogspot.in/2012/06/2005-chrysler-pt-cruiser-ac-blows-warm.html
A/C blows Cold From Defrost Vent Only? http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
A/c Blows Warm on driverside? http://whatisbyme.blogspot.in/2012/06/2007-kia-spectra-ac-blows-warm.html
A/C compressor clutch won't engage http://schematicsdiagram.blogspot.in/2012/04/2000-cadillac-deville-ac-compressor.html
Ford : A/C blows Warm? http://whoisbyme.blogspot.in/2012/06/2007-ford-freestyle-ac-blows-warm.html
Thanks.
Jun 26, 2012 | 2005 Ford Five Hundred
How to fix a/c and heater on 2002 chevy trailblazer?
The blend door is most likely not operating correctly
Apr 01, 2012 | 2002 Chevrolet TrailBlazer
Cold and hot stiky air
try cleaning the filter and fan blades.
Jan 01, 2012 | Heating & Cooling
Power to ac but will not turn on
Please give more details if possible. Roof air, with mechanical controls at ceiling, or thermostat on wall? Ducted system in ceiling or blows right out of ceiling assembly? Can you get a model number off base of upper (roof) unit, it should be visible when you remove filter from ceiling?
Jul 22, 2011 | Dometic Rooftop RV Air Conditioner
My ac/heater unit on my roof it blows warm air for ac and it has no air for heater. what is my problem?
check fan motor of heater if woking if not check capacitor if deform it means cap. defective replace new one the same rating. clean air filter maybe it clog with dust.
Jan 29, 2011 | Goodman GMS90703BXA Heater
I have a 2001 expedition 4.6 liter. The air works great but when you turn on the heater it doesnt get warm. air blows out but its not warm. what is the problem? please help
is your engine antifreeze at correct levels is thermostat opening and closeing at correct engine temp theres a little door up inside your air duck that switchs it self when you switch from ac to heat it may be stuck open
Dec 01, 2010 | 2001 Ford Expedition
1998 Isuzu Rodeo is having issues.
check to see if AC and HEATER blower motor is getting power .if yes replace blower motor.if no you have problems in relay- fuse- or ac and heater switch is bad.for sun roof check for power at switch if yes sun roof eletric motor need replace.or sun roof in a bind.if no power to sun roof switch.blowed fuses and bulbs or turn signal switch is bad.
Jun 21, 2009 | 1998 Isuzu Rodeo
2000 roof-top Brisk-Air
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Jun 09, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
69 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
