Question about Polaris 280 In - Ground Pool Cleaner with Booster Pump
Sweep hose end keeps getting sucked into bag, any suggestions how to fix?
  • 22 Answers
Turn down the pressure at the adjustment screw on the side of fiting where hose connects to unit. then move the wear rings to differenct positions on the hose. you may want to cut the hose shorter as a last resort. unattach the sweep hose from the unit and let it sit in the hot sun for a few days then stretch it out straight while setting in the sun alot of the time the problem because it was never layed out straight from the time it was removed from the box and installed in the pool all the cleaner hoses have memory and you should never loop them at all infact once or twice a year I remove my cleaners from the wall fitting and lay the polaris in its side two wheels and stetch all hosese straight then let sit in warm sun for a few days to a week this will soften the hoses and keep them from wanting to let the unit go in circles and loop the hoses make sure all the swivels are pointed in the right direction there is a little arrow engraved in side of hose swivles the water should flow in the direction of arrow. make sure mender nuts are secure periodically
Posted on May 14, 2010
Testimonial: "thanks, great advice!"
Miele not sucking
1. Check if the bag is full. Yes. Change bag.
2. Check the head. Clean head.
3. Object stuck in the hose. remove hose from the vacuum. Remove extensions from the Head end. Poke garden hose down the hose from the handle end.
4. If all else fails. Read the destructions.
Jul 05, 2014 | Miele S318 Bagged Canister Vacuum
Vacuum goes on for a few seconds then shuts itself off when I go to start again it goes for a few seconds then stops new bag in vacuum can I fix this problem Donna
First, turn dial on top of vacuum counter-clockwise so the smallest dot lines up with the arrow. See if it stays on. If not, detach hose and turn vacuum on. Place palm of hand over intake. If it turns off, it's possible that the tubes connecting to the CVA are clogged and simply need cleaned. This is most often caused by using "made to fit" Electrolux bags. Dust is sucked through the bags and into the motor compartment of the machine. All interior parts get covered in dust and need to be cleaned. If this is the cause, the vacuum is best cleaned and repaired at an authorized Aerus Electrolux store. If the vacuum shuts off, or won't turn on before placing hand over the intake, it's probable the control valve assembly is bad and needs replaced.
Another cause is an overheated motor due to clogged screen at back of bag well, full or clogged bag, dirty afterfilter, bad wiring/connections, clogged hose, clogged power head, or bad motor. It depends largely on the type and model of cleaner. Clogged wands are also a possibility, but unlikely.
Check and clean screen at back of bag well.
Replace bag. Make sure it's a genuine Electrolux bag made by Home Solutions.
Check and replace afterfilter if necessary. These should be replaced after every six bags.
Broken and worn wiring connections are often found in the hose ends due to abuse and normal wear and tear. You can check the continuity of the hose using a continuity tester or multi-tester. If a multi-tester, turn dial to one of the Ohm settings. Place one probe into one of the terminals on the end of the hose. This will be referred to as T1. Touch the other probe to each of the terminals/connections on the other end of the hose. These will be T3 and T4. One of them should read zero, the other should read infinity. Repeat this with the other terminal, which will be T2.
Drop a marble in one end of hose and let it roll through. If it doesn't roll through, the hose is clogged and needs to be cleared. Plug hose into the exhaust port of the vacuum, place other end in the in port. Turn vacuum on. This provides a blowing and sucking action which should clear the hose.
Detach hose from power nozzle (PN). Drop a marble into the wand end of PN. If it rolls through, it's clear. If not, there's probably a clog behind the brush where the intake opening is. You may be able to reach this through wand end with needle nose pliers, or either end with a knitting/crochet needle or a bent coat hanger.
If none of these "fixes" provide the answer to the problem, it should be taken to the nearest Aerus Electrolux store for diagnosis. Repairs or checks involving disassembly of the vacuum should always be done by an authorized Aerus Electrolux service technician.
The store nearest you can be found by following the instructions at the below listed link:
http://www.aerushome.com/storelocator/
Apr 06, 2011 | Electrolux Lux 7000 Bagged Canister Vacuum
I have an electrolux epic 6500 sr. The change bag light came on, I changed the bag, now it won't run properly. If the bag is out and the hose attached it will run or if the bag is in and the hose is off...
First, if it runs without a bag, there's a problem with the bag lock-out switch or wiring. This needs to be replaced/repaired by an authorized Aerus Electrolux technician.
Mar 21, 2011 | Electrolux Epic 6500 Vacuum
Aerus/Electrolus canister vacuum model C152C turns off and full bag indicator lights even with new bag.
Here is a list of things that could cause this, and how to check and/or "fix" them.
Mar 11, 2011 | Vacuums
Changed bag and filter, filter light keeps coming on, not working
Jan 12, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Keeps opening as if the bag is full. HOw do I fix this.
Dec 28, 2010 | Electrolux Lux 5500 Canister Vacuum
Moves slowly and the stops. looks like diapham doesn't open back up
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Nov 28, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
VACCUM KEEPS SWITCHING OFF /NOT SUCKING
First thing would be to check the bag as it may be full. If the bag is full the machine will overheat quickly. Also check the internal filter in the bag cavity to make sure that isn't dirty.
Next, check there's no blockage in your floor tool or in your telescopic rods.
As for the hose: grab a marble and see if that will go all of the way through the hose. Marble goes through = no (big) blockage. Marble won't go through = blockage.
There possibly could be a blockage in the bend/handle. Grab a bendy coat hanger and undo it, make a small hook on the end, and use it to stick up into the handle to check for a blockage.
To check from the other end get a broom handle and stick that in at the machine end of the hose. If you find a blockage, get the coat hanger, stick it in, and rotate it gently around and hopefully hook whatever the blockage is with the hook on the end.
Mar 29, 2009 | Vacuums
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Polaris 280 In - Ground Pool Cleaner with Booster Pump Logo
337 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
