Question about Haier HLTDC19 TV
Dvd problems My HLC19K1 dvd player suddenly doesn't read a disk. It has a message of no-disk. And when the tv is turned on the player motor comes on by itself like when you feed a disk in. I can hear it run and then it sounds like it reverses and runs, it cycles like this a few times and then finally stops. But the tv works fine.
  • 4,234 Answers
There are actually 2 separate issues here.
1) The initial motor you are hearing is the "powerup" checking that is normal. Usually the motor does not try to insert or eject a disc so perhaps there is an internal timing or reset issue.
2) The no-disc message can occur for two reasons:
a) The disc is not loaded properly and can not be read. This is interpreted as a bad disc rather than a loading problem.
b) The disc loads properly, but it really cannot be read.
For case 2b, if you can access the DVD optics, try cleaning them with alcohol and a cotton swab. That may resolve the problem.
For case 2a, the unit will need to dis-assembled and "re-timed". This is not a DIY repair.
The bottom line here is that this is not likely to be a motor problem and rarely is that the issue. I would first look for a dirty lens than a slipping loading belt.
Ragards,
Dan
Posted on May 14, 2010
  • Haier Master
  • 3,866 Answers
The issue is the motor will need to be replaced, And why i always suggest to cosumers not to buy all in ones for this purpose. The labor to fixy this is over $100 bucks alone and the part you need to replace the entire dvd unit in this.
1. check your warranty
2. bring it to a shop to have the unit fixed
Thanks and please do leave positive ratings and feedback for your free answer today.
Posted on May 13, 2010
  • Grand Canyon Tech
    Grand Canyon Tech May 15, 2010
    I'm going to assume that you're having this problem with all DVDs and CDs that you insert into the drive. If this problem only occurs on one disc, the problem is usually with the disc itself.
    There are many reasons why a DVD player may be incapable of recognizing a DVD when inserted.
    1. Many DVD players are not able to properly detect and playback recordable DVDs. If trying to play a DVD disc that is a DVD-R/RW or DVD+R/RW, you'll need to refer to the DVD players documentation on compatible formats.
    2. Insert the disc and listen closely by placing your ear to close to the drawer of the DVD player. After the disc tray has closed, you should be able to hear the disc spinning. If you hear no such sound, it is common that the disc is not spinning up, which is why you would recieve a "No Disc" message when a disc has been inserted. In some cases, it can be difficult to hear the disc spinning, so you could remove the lid of the player to actually see if the disc spins.
    3. If this is the case, you could try to determine the cause of this, which is usually the "hat" above the center of the disc is stuck and needs to be repositioned to lay against the top surface of the DVD. If you are
      GA_googleFillSlot("TL-IMU-Article");
      uncomfortable doing this, you'll want to bring the DVD player to a service center.
    4. In your case, the DVP-S560D is an older DVD player, and I'm sure it has had its fair share of use. Over time, dust and deposits can accumulate on the laser that reads the disc. In many cases, DVD players with this problem can still read CDs. You could try a DVD laser cleaner, which is usually a disc that has a tiny brush glued onto it. Run the cleaning disc 2 or 3 times, and try it again. Try both CDs and DVDs, since CDs are easier to read than a DVD.
    5. After a DVD player has been used for awhile, another common problem is that the laser in the DVD player becomes misaligned, inhibiting its ability to read DVDs. In many cases, DVD players with this problem will still be able to read a CD. I'd try a cleaning disc first, since the only way to fix this problem is to bring the unit to a service center for repair.
    6. There are other possibilities for the players failure, such as a defective laser motor (the motor that moves the laser), bad spindle motor (the motor that spins the disc), as will as other various circuit falures that could be the cause.
    Try all things you can do yourself to repair the unit. If none of them are successful, you will need to have the unit repaired, or purchase a new DVD player. As a general rule-of-thumb, if the unit repair cost exceeds 2/3 the cost of a new comparable unit (in both features and quality), then don't bother fixing it. You'd be better off with a new player.
    Let us know how it goes by following up
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Will not read CD's
get a dvd cleaning disk that comes with cleaning fluid ( it it doesn't have fluid with it don't buy it) or bring it in for repair to have the lens cleaned. if cleaning doesn't fix it then the lazer is bad or motor.
Jun 17, 2011 | Sony MXD-D40 Mini Disc Player
I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
DVD starts to load but does not play.
Not sure if anyone found this solution, worked for me.
1. Press SETUP
2. Press FFW, F REW, NEXT, PREVIOUS
3. Change the code to 255 using the RIGHT arrow key
This will unlock the DVD player for all regions.
Jan 26, 2007 | Coby TFDVD5000 Portable DVD Player
Haier HLTDC19 TV Logo
159 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
