Question about IBM Office Equipment & Supplies
MY WHEELWRITER 6 WAS WORKING FINE UNTIL TODAY IT STAYS ON THE LEFT HAND SIDE AND WILL NOT MOVE TO THE RIGHT. IT MAKES A LOUD NOICE. I DO NOT SEE ANYTHING STUCK AND THE BELT IS INTACT HELP
  • IBM Master
  • 3,594 Answers
Check for objects and debris under or around the carrier, with it off see if you can move the carrier back and forth, check the battery pack to be sure it hasent be come disloged. If you can move the carrier put some WD40 on the silver shaft it slides on.
DickyO
Posted on May 14, 2010
Wheelwriter platen latch removal
Very vague question. the left side you have to drive the pin out.
right side just a clip.
If the platen wont stay down you can carefully wire it down so it doesnt interfere with the carrier is moved to the left.
Or buy a used platen.
Sep 12, 2015 | Lexmark Wheelwriter 6 Series II Typewriter
I have a mazda 6 s 2003 that make a loud humming sound wile driving but if I turn the steering wheel a little to the right it stop. if i turn left it doesnt do it but it started to make a grinding noice....
The humming might be an wheel miss-alignment. and/or
Grinding maybe the steering box (rack and pinion)?
******* ALL this could also be a worn out BALL JOINT, in which case you should have this checked out RIGHT AWAY!!!
VERY DANGEROUS to drive!!! ******
Feb 06, 2014 | Vehicle Parts & Accessories
Carriage return stuck on left side when powering on
The first thing to try is to lubricate the silver rail that the carriage rides on. A few drops of a light oil ( sewing machine oil ) may take care of the problem. Turn machine off, apply oil and move carriage by hand back and forth. Turn back on and see if this took care of it.
May 14, 2013 | IBM Wheelwriter 6 Typewriter
1994 Oldsmobile Bravada - Driving - Loud Noices
Sounds like worn Constant Velocity Joints (CV Joint)
to me.
Feb 27, 2010 | 1994 Oldsmobile Bravada
This is regarding a ibm wheelwriter 10 series ii it is "stuck" on the left side & will not go to the right at all. Margin release will not help, tried turning off & on, tried unpluging. HELP...
Can you move the carriage asm with your hand with the power off? Move it all the way to the right. Turn it on and see if it now will move to the left. If it makes a grunting or shrieking noise. Lubricate the main silver colored shaft.
Dec 30, 2009 | Office Equipment & Supplies
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
IBM wheelwright 15 series 2
Try puting some light oil (WD40 works well) on the silver shaft that the carrier slides on, also check for debris it that area.
DickyO
Jul 06, 2009 | Lexmark Wheelwriter 15 Series II...
Stove cutoff after loud popping sound
The element burnt in to and arced which is the loud noice you heard red flash of light. It probably tripped the breaker at the electrical panel. Don't turn it back on until someone checks the element and replaces it.
May 28, 2009 | Kitchen Ranges
IBM Wheelwriter 6 Problem
The lights blinking indicates an error code, that mean a keyboard error or posibly a problem in the start up procedure. This is a problem that would have to be solved in a repair shop.
Oct 27, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Dec 20, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
47 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
