Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Stops after tub fills
After the tub fills with water it stops, the agitator cycle doesn't appear to be moving at all....if I pick up the back of the machine and set it back down, it sometimes "jump starts" the agitator cycle, but it doesn't always work...
  • 6,784 Answers
HI, This is the result of a failed control sector. The timer is damaged, at this time.The timer is the principal initiator of all actions during a selected cycle. This device should be replaced, asap. It is located in the control panel. it is easily access through the back side of the panel. You Will need ot pull off the dial on the front of the panel before extracting the module for replacement.
Failure to advance to the next interval will always be the fault of the main control sector in most units of this nature.
Posted on May 13, 2010
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Will agitate but won't spin leaving the water in the tub.
the transmission may have been damaged during the runaway.to much movement can cause it harm that is why they come with a shipping rod in them.
Aug 08, 2009 | Kenmore 22422 Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Another flood. GE washer
The water sound is normal. There is a solution in the top of inner tub for balance. Is it overflowing...as in not stopping the fill cycle? If so check to make sure small hose is still attached to outer tu at bottom left front. This dome that it connects to can become filled with scum and causes the unit to not know that it's full. This causes flooding. You can try removing hose and cleaning out with thin wire. Sometime only fix is to replace outer tub. Again, this is only if overflowing!!
Another possibility is a bad break allowing outer tub to spin in agitation. This throws water up over sides of tub. Monitor unit when agitating to see if outer tub picks up speed and starts to spin. It is normal for it to index.
Nov 08, 2007 | GE WDSR2080D Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
