Altec Lansing BXR1121 2 Speakers Logo
Posted on May 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The two speakers dont work.One of them does not
The two mall sspeakers dont work.One of them does not work(no sound from that one) while the other works fine for very low volume only(at moderate volume very distorted sound comes).the sub-woofer is fine.
Anonymous
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on May 13, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
17166
Points
198
Check the cable may be cable from first mall speaker problem
Where is the nearest Bose repair centre in Durban South Africa ?
Contact Bose in South Africa to see if they can provide assistance to you.
https://global.bose.com/en_us/africa_middle_east/south_africa.html
REGION AFRICA & MIDDLE EAST
South Africa
For Home Entertainment and Personal audio products
Sound Imports
Shop C228 Rosebank Mall
51 Bath Avenue, Rosebank
Johannesburg
South Africa
Email: [email protected]
Tel: +27 11 880 1933
Sound Systems
50 Bath Avenue, Rosebank
Johannesburg
South Africa
Sound Systems
49A Somerset Road, Somerset square
Green Point, Cape Town
Cape Town
South Africa
Tel: +27 21 421 4289
For Professional products
Alpha Technologies
Unit B5
Northlands Deco Park
Newmarket Road
Northriding
Johannesburg
Republic of South Africa
Tel: +2711 462 5495
Sspeaker ohm?
Not sure what you want, but the resistance of a speaker is called impedance and is measured in ohm. Read all about the importance of this and why it is important to use the correct impedance. Speaker Impedance Explained Ohms
1helpful
2002 Mazda protege LX - Factory radio and after market radios both test good on the bench but dont work when installed in the car. Connectors seem to be OK. Speakers in the car test out good. Occasionally...
one of your speakers is blown and shorting out your deck. disconnect one sspeaker at a time and when it starts working fine you know that's the blown one.
COLOR CODES
colors for sspeakers on an aftermarket radio? solids are positive and black stripes are negative. whites are front eft, greys are front right, green is rear left, and purple is rear right
I have built in sspeaker in the system but its not
That is not a full blown sound speaker and is these simply for the beeps you mention.
Real sound is generated by the sound card.
The GREEN port on the back is where you plug your speakers in but you also have to install the drivers for the sound card itself
Bob
EXMOD
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Installing a KDCX-592 in my son's 95 Nissan Pathfinder. It has a power antenna. It powers up but we can not get sound from the unit using an aftermarket harnass. The unit will drive a a speaker hooked...
get the "nissan to kenwood" factory converter harness available at best buy. but if you don't want to pay best buy prices, go to a local mega mall or swap-o-rama, and go to radio and sounds spot there
Because of Gigaware headphones, my speakers dont work
it sounds like the headphones shorted out the usb on your system, you might try some speakers that are not usb and see what you come up with,,,also check and make sur your sound isnt muted on the master control for the volume
No sound...
you have wires grounding out at the back of the unit. i suggest trying to completely rewire it and see how that works. its easy if youve never done an install so dont sweat it. email me if you have any questions.
[email protected]
Amp protection circuit
disconnect all speaker leads at the unit,power it up then see if it'll stay on. if it does, reinstall one speaker lead at a time until it goes into protect mode. that speaker line will probably have a short in it. Just run a peice of skr wire straight from the unit to the sspeaker in doubt, hooks em up see what happens. if it shuts down have that skr ckd.if it works, just rip out the old shorted line and run new stuff.
2answers
When on the cingular mall trying to download ringtones it jumps to the top of the page.
My mall connection wont work i dont know why i have texting and i can call and everything but how can i fix this problem it says connection unseccsuccfull try again later
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
 Grubhead
Grubhead
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
