Question about Whirlpool LER4634J Electric Dryer
Dryer spinning but not drying!
I have a basic type (Whirlpool) electrical dryer that spins on for hours on end but will not get hot; what's the problem?
    President:
  • 2,468 Answers
If it runs with the door open the door switch could be defective,otherwise check your heating element high limit/cycling thermostat switch,then the thermal fuse on the side of the vent housing.and also check the power input for 240 volts a.c. if its an electrically heated element,if inside the terminal strip any terminals burn or break off the element can't heat/if its a gas dryer,check the thermal fuse,the high limit thermostat,the radiant sensor on the burner tube or the gas boost and secondary coils on the gas inlet valve,they get weak or open and close off the gas supply
Posted on May 13, 2010
Whirlpool gas dryer (LGR8648PW1) doesn't stop spinning in automatic mode.
More than likely a bad timer assembly. They are usually easy enough to replace if you have basic mechanical skills. The part can be ordered from repairclinic.com.
Jun 26, 2012 | Whirlpool Dryers
Dryer does not dry clothes after 1 hour but seem like its getting hot
it might be the washer it is not spinning as much water out of the clothes as when it was new try double spinning the water out of the clothes
Feb 27, 2011 | Roper REX4634KQ Electric Dryer
I have cleaned vents ducting and still have drying problems gets hot but not drying clothes. whirlpool duet front loading dryer. takes 3 to 4 hours to dry.
go to the end of the vent and actually feel if there is air coming out if not you either missed a plugged vent or the blower is not working. deep inside the lint trap is a hard spot to find it plugged als can you hear the drum spinning
Oct 30, 2010 | Whirlpool Dryers
My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
No hot air
clean all vent tubing and try again
the moister sensor will keep the burner off if lint is build up inside the exhaust duckwork
May 09, 2010 | Whirlpool LER5634L Electric Dryer
Whirlpool electric dryer leq7030kq1 wont turn without help
Sounds like you have a dead zone in your motor...could be a replacement motor is called for. or continue to spin the drum by hand till the motor goes kaput...its cheaper
Sep 26, 2009 | Whirlpool LEQ9858P Electric Dryer
Dryer that is getting warm, but the drying power is missing. I am trying to dry towels, socks and t-shirts that are on their 4th spin and the items are still not dry
check your wattage on back,then do load check with amp meter,verify that all of elements are working-watts=voltsxamps,a link may be burnt at elements or element has failed,hope this helps
May 08, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer LER4600PQ1 - Drum spins, but no heat!
clean vent,and check circuit breaker.if that is not problem,could element or thermal fuse.
Mar 08, 2009 | Whirlpool LER5636P Electric Dryer
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
189 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
