Question about BMW 3-SERIES CONVERTIBLE
MY 99 BMW 318 SERIES CONVERTIBLE ROOF WONT OPEN MOTORS ARE WORKING MIGHT BE THE RAILS ? HOW EASY TO FIX
  • 107 Answers
There is an inhibitor switch built into the boot lid if it is faulty or boot lid isnt closing properly roof wont fold up (or down)
Posted on May 16, 2010
BMW Z4 convertible top opened and now wont close. Motor runs then stops. Latch is stuck and the emergency pull cord will not release. How do I get to the latch to free the top?
try a spray lubricant into the motor mechanism and grease any visable wire cables that run from/to motor ,not the electrical cables the bare wire winder cables,also grease/ lubricate any accessable pivot/hinge points , gently pull the cord and gently push the roof back and forth occasionally trying motor with a bit of patience this should get the roof moving , also look for anything that may be snagging the roof/mechanism as there is a pressure protection system to stop the roof being fully closed on say someones hand so preventing injury
May 03, 2014 | 2004 BMW Z4 Roadster
BMW roof is stuck closed with only one latch hooked!
There is a compartment on the top center of the windshield. This contains a bolt that released the latches that lock the top to the windshield. It takes an allen wrench to unwind the roof latch and it takes an infinite amount of turns.
Jun 04, 2017 | 1999 BMW 3 Series
Where can i order online a top lock drive cable on a 97 318 bmw convertible please,drivers side it goes from motor centre of roof to the lock/catch
dealer only these sort of parts so take chassis number to dealers and order one its the only way you will get the right one
Mar 26, 2011 | 1997 BMW 318
My roof goes down half way any easy fix
check to see if anything is stuck in the path of the roof when it is going down. It is most likely jamming up somewhere or your motor that lowers the roof is going bad
Jan 10, 2011 | 1997 BMW 318
1997 convertible bmw318i top roof storage wont open? what sould I do? I only heat clicking when i pull the latch by the passenger side.
1997 328i convertable. The lever was pulled under the left rear seat. Now the top will not work, light is blinking. I checked all fuses, assured motors are back in place and the light is still on, not working at all, what am I missing?
May 02, 2010 | 1997 BMW 318
My sunroof is stuck open on my bmw the electric is out i have checked fuse is there a manual way to close it?
There is no way or closing it manually sorry unless you have various BMW tools. The problem sounds like the electric motor went out on it. Its located right above where all your interior lights are. Pop the cover of for the lights and try tapping on the motor while your trying to close it with a small hammer lightly to see if you can get it close. Another thing that happens alot on the E 36 is that the plastic aliging pins on the rails will brake over time with use and than this will cause the sun roof to get stuck open or partially close. This will be the case if you ever heard a loud snap.
Sep 15, 2009 | 1997 BMW 318
1999 bmw 328i convertible trunk will not open with button or key what do I do
UPDATE: I thought I was posting regarding a 1998 E36. Not sure a 99 has the same fuse or interlock.
Jun 24, 2009 | 1999 BMW 328 Series
1997 Convertible BMW 318i top roof storage wont open
Hi, I don`t know the car but sometimes when you can`t open a boot lid someone need to push the boot lid down ( this relase the pressure of the latch system)and the same time someone pull the handle. Hope that helps.
May 28, 2009 | 1997 BMW 318
1993 325i Power Convertible Top will not open
has to be rest and tested by bmw dealship something has caused the roof to stop possible the control unit failed, a faulty microswitch in roof or the straps in the roof have failed and thrown it out of timing, cauing it to shout down system.
Nov 30, 2008 | 1997 BMW 318
Convertable roof and trunk won't open
The Roof Mechanism works with two motors similiar to the ones that wund the windows. Now the two mechanism are located in the left side of the trunk.
The trunk wont open Because of the roof lid that is not closed properly. How you can test this is to press down on the right sid of the roof lid and then try to opne the trunk.
Now the reason that this is happening is that the roof lid is not closing properly nad pressing on a small orange buttin located just below the right hand side roof lid catch. How you are going to remedy this problem is to adjust the cable tension to close more securely.
Now the two motors in the trunk that works the convertable roof can be engaged and disengaged on motor works the roof lid and the other one the roof.
You need to get these motors in sync so that they open and close the roof in the correct order.
That is if the electric are still working.
Jul 24, 2008 | 1997 BMW 328
BMW 3-SERIES CONVERTIBLE Logo
263 people viewed this question
Top BMW Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a BMW Toy Expert? Answer questions, earn points and help others
