Question about Garden
WIIL NOT START, spark plug good - Garden
    Scholar:
  • 142 Answers
Posted on Oct 02, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Is there spark at the plug. if yes then check fuel supply
Posted on May 13, 2010
Wiil turn over but won't crank fuel isn't getting to plugs
check fuel pump fuses ,relay.wires and connections if good possible fuel filter didnt give vehicle information so if filter is in tank incorporated with fuel pump need to change both or an external one
Jul 27, 2015 | Cars & Trucks
My car wiil turn over but will not start what is wrong with it
battery connection,weak battery,fuel filter,spark plugs,distributor cap,dirty throttle body,weak fuel pump.
Feb 20, 2013 | Cars & Trucks
Why does my 1997 honda accord have oil around the spark plugs?
You have to replace the Valve cover gasket. Inside the spark plug hole, midway down is a gasket, every spark plug hole has them, you cant see it because its, well a gasket pressed against two very tight suface every spark plug hole, When these leak they fil up the sprkplug cavity, as you know. Go to a parts store, spend $30 dollars on a VALVE COVER GASKET SET. If reparied properly wiil be a 100% fix. If it's a 4 cylinder honda,, a monkey with downs syndrom could do this in five minutes. V6 accord, save yourself the time, grief and heart ache, and take it to a Professional.
Dec 06, 2012 | 1997 Honda Accord
2004 chevy cobalt it wiil not start
If the engine will crank but not start you will need to find out if you are dealing with a no spark or no fuel issue to proceed.
Sep 05, 2012 | 2004 Dodge Caravan
95 vilager 3.0 die when its hot out. when i let it cool it wiil run for awhile, any time its 86 degrees or hotter i have this problems not sure (ignition mod, coolent sensor, weak fulpump, vaperlock)
When it dies you need to figure out what is missing, ie fuel pressure, spark, tour are probly losing spark when it occurs pull of on of the plug wires at the coil and have someone crank the engine while you hold that wire 1/4 inch away from being plugged in not touching but close, see if the spark jumps this gap, of not you have either a failing coil pack, or a bad crankshaft position sensor, I would start with the coil, please rate or leave feedback good luck
Jul 31, 2011 | Mercury Villager Cars & Trucks
Wiil not start has no spark change crank sensor still no spark
Check the coil connection and the fuses for ignition. If your car has an alarm with the kill switch, reset it. This is also common.
Jan 05, 2011 | 1998 Chevrolet Lumina
Hello,I have a 2004 F350 super duty. It wiil not
You could try jumping the relay mounted on the fender carefully with a screwdriver accross the terminals to see if the relay is defective.
May 18, 2010 | 2004 Ford F350
Will not start
first check for spark then check ignition switch and coil and that's a good place to start
May 14, 2010 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Chevrolet s10 pickup wiil not start
No enough information to offer directed assistance. Does it have fuel, does the motor turn at speed with the ignition switch. Are you gettting spark at the plugs? Do you have compression in the cylinders. The motor requires Fuel, Air and Spark be delivered at the correct moment of time. Start with the basic and figure out what IS working then no matter what is left, repair or replace it. I ALWAYS purchase the shop manual for any vehicle I am going to work on, they almost always offer me some information that I might need to complete the job.
Aug 31, 2009 | 1998 Chevrolet S-10 Pickup
My samsung i760 wiil not sync today. i run windows xp and have microsoft active sync 4.5. the pc connects to the phone but sync wiil not proceed.
Try to unplug the usb cable or the sinc cable and wait a few seconds and then plug it back in, be patient...If that don't work reboot the computer. Good Luck and don't get too frustrated.
Feb 14, 2009 | Lands Phones
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
