Question about Maytag Neptune MAH5500B Front Load Washer
Cold water is barely trickling into the washer. How do I clean the filter/screen? Yes, we have well water?
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about no water coming into the washing machine...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Posted on May 14, 2010
Only hot water fills the washer...no cold water, even if you put it on cold water only...it then just barely trickles out.
you may need to remove the cold water supply hose and clean out the water valve.There should be a small screen that needs to be removed and cleaned.If that does not change any thing you may need to replace the water valve.
You can also change the hoses around for a quick test of the water valve.
Mar 08, 2011 | Washing Machines
Machine won't fill up with rinse water, it washes & spins but the water only trickles in the rinse cycle, i ahve been filling it up manually
Turn the water supply off.
Remove the COLD water hose from the rear of the washer.
Clean the silt out of the COLD water valve on the washer.
Re-attach the hose on turn on the water supply.
Jan 21, 2011 | GE WBSR3140DW Top Load Washer
When the dial is set on cold water trickles in but on warm/hot water runs in normally.
Turn off the cold water faucet. Remove the cold water hose from the rear of the washer. Use a bent paper clip to remove the filter screen from the water valve inside the cold water hook up. Clean the filter screen and replace it.
The screen must be in place to prevent damage to the water valve.
Jan 10, 2010 | Kenmore Washing Machines
Hot water barely trickles into washing machine
Check the hose at the end where it connects to the washer (the inlet valve unit). There may be a screen there also that needs to be replaced or cleaned. If not then the hot water solenoid valve is probably gunked up with the same type of stuff you found in the filter screen. You may be able to clean it enough to get it to work but replacing it is just as easy and not very expensive. (Even cheaper see if you can salvage one from an old machine at the dump or that someone has left at the curb--the units are very standard across many manufacturers in the tU.S.) Both the hot and cold water valves are in the same unit.
Jul 23, 2009 | Admiral AW22 Top Load Washer
Rinse water barely trickles out of my washer
Do you fill the machine with hot water only?
If so, this is what I suspect. The filters in the inlet hoses on the back of the washer need cleaning. Remove the garden hose connectors, remove filter, clean, replace.
When filling with hot only you get a lot of pressure thru one hose. When you rinse, the best you can do pressure-wise is cold rinse -- but the cold water filter is going to be more clogged than the hot so it delivers less water.
When you use warm rinse, you get mediium pressure thru both lines, again less water than al hot on filling the machine.
Apr 29, 2009 | Washing Machines
Water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Jan 10, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water filling
There are filter screens where the supply hoses connect to the washer. On some brands there is a screen where the hose connects to the water valve at the wall. The screen is probably full of sediment.
Dec 14, 2008 | Kenmore 24622 Top Load Washer
Whirlpool washer approximately 2 1/2 year old
The screen at the cold water inlet is clogged. Cut off the cold water line and unscrew the line to the washer at the washer. Use a flathead screwdriver and pry out the metal screen that is visible Wash it out in a sink and re-install it. Re-attach the water line,turn it on and your'e good to go. If not you will need a new water inlet valve. These are the only things that can cause your problem unless there is a problem with your cold water supply pressure. Good Luck!!!!!
barneyluc
Oct 03, 2008 | Washing Machines
Washer fills slow only in the rinse cycle
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
490 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
