Question about SVA-USA SVA 19" LCD TFT MONITOR
Monitor blinking off & on rapidly. Just started it out of the blue during use. Turned off computer over night. Still having same problem after re-booting this morning.
  • 80 Answers
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
I just got a 1.5 TB WD ext HD. It blinks evenly & slowly when the computer is sleeping. It blinks rapidly when the computer is awakened, & becomes solid during the time the computer is...
Seems perfectly normal, the slow blink while sleeping shows you that it is active but not in use (witched off but immediately available) The rapid blinking is the machine accessing the disk and the constant light means it has power but not connected. The occasional blink is probably the HDD parking the reading head or shutting down the disk or both.
Nothing to worry about.
Jan 15, 2011 | Western Digital My Book Essential 1TB...
Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Jan 01, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Hi, my 713N monitor worked last night. i turned
That shows you that the problem is not your monitor
but your operating system is not booting or is hung
turn off your computer & restart pressing F2 as soon as it starts to boot up select open in last known configurationto see if the O/System will know boot up
If this Fails &you are not a experienced enough to do a repair sequence from your O/S disc .Reinstall your O/System
Dec 03, 2009 | Office Equipment & Supplies
Rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Oct 27, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
No picture - blinking blue light. My daughter was
There are a few things you can check. First, try to see if the monitor cables are firmly connected on both sides (computer and monitor) no need to remove any cable for now just check the monitor cables (ends should be blue or white on both sides) Then check if you got an imput button on your screen (like all TV and some monitors now has) This input gives you the choice between a few possible connections and it may be on the wrong one. Just cycle trough the input modes and I think you will have your image back. If Still, you dont see anything, try a different monitor or try to connect your monitor on a different PC/laptop. In fact blinking blue could be there because the monitor is awaiting a signal on the input it's listening. At worst it could be because your video chip/card dont send a signal to your monitor, could happen, but imo it's probably not the case.
Jun 08, 2009 | Gateway 1532121 Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
My Gateway monitor FPO 1975W is blinking?
Hi there, it sounds like this monitor is going out on you. Try a different monitor if you can, see if that fixes the problem!
Apr 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor dosn't atart
Check SDL,SCL Path and It's related parts(Neck board PCB 2 MICOM)
check Output Voltages of SMPS
And also check dry points.
Oct 14, 2008 | LG Studioworks 700S 17" CRT Monitor
SVA-USA SVA 19" LCD TFT MONITOR Logo
173 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
